1970 TA P/S box and fast ratio pitman arm question #894784
01/02/11 06:53 PM
01/02/11 06:53 PM
Beans Cove Pa
Bumbalawski Offline OP
Beans Cove Pa
My friend is thinking about puting a 1970 TA power steering box and fast ratio pitman arm on his 70 Cuda, but he is wondering what such a unit would cost if he could even find one. He wants an original unit, not a repop.
dodgeboy69@atlanticbb.net
thanks,
Don
Re: 1970 TA P/S box and fast ratio pitman arm question [Re: Bumbalawski] #894785
01/02/11 06:59 PM
01/02/11 06:59 PM
NW/Indiana - Chi town
ricomondo Offline
ricomondo  Offline
Boxes can be anywhwere from $350-$700
Pitmans from $150-$275
Just tell him to shop around,
And to make sure the box has the
"TA" cast into it.
Im not aware of any fast ratio Trans Am boxes without this cast into it.
GY3 71 Demon 340
Re: 1970 TA P/S box and fast ratio pitman arm question [Re: ricomondo] #894786
01/02/11 07:06 PM
01/02/11 07:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And I would say why bother spending big $$ for a T/A box when it doesn't have a faster ratio, it doesn't have modified valving... It only has different internal travel limiting stops... I would use a box modified by Firm Feel with improved valving for more steering effort & better feel.. Then the longer pitman arm and idler arm... Yes if you turn the steering to lock the tire can rub the frame rail but if you have half a brain you quickly figure out how many turns you need to turn a circle & how far you can turn in till the tire touches the frame...
Re: 1970 TA P/S box and fast ratio pitman arm question [Re: ricomondo] #894787
01/02/11 07:08 PM
01/02/11 07:08 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Just put a Fast Ratio pitman and Idler on from www.firmfeel.com to his existing box.
The only thing significantly special about the T/A box is that is has internal stops to prevent some complete idiot from cranking the wheel to full lock, holding it there, and possibly rubbing against the inner frame rail.
People do this all the time and they don't buy the "T/A" stamped box. That's a waste of money for a car that didn't originally come with one.
I think Firm Feel can rebuild you box with the changed internal stops just like the original T/A box if you wish. And you get a good rebuild box, instead of one off some parts car that's been sitting around for 10-15 years plus.
Re: 1970 TA P/S box and fast ratio pitman arm question [Re: autoxcuda] #894788
01/04/11 12:19 AM
01/04/11 12:19 AM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I did this mod to my 1970 dart swinger.
See the pictures in this outer post.
http://www.forabodiesonly.com/mopar/showthread.php?t=108037
Re: 1970 TA P/S box and fast ratio pitman arm question [Re: autoxcuda] #894789
01/07/11 02:10 AM
01/07/11 02:10 AM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
I'd like to get a set of these, but Ive got TTI headers. Any chance running just the longer pitman arm would work?
Re: 1970 TA P/S box and fast ratio pitman arm question [Re: sixpack4spd] #894790
01/07/11 02:26 AM
01/07/11 02:26 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Yes, you can use a long pitman arm and short idler. Also 2" TTIs will clear the long idler and pitman on an e-body
