fan numbers for my 69 440 #894599
01/02/11 02:25 PM
01/02/11 02:25 PM
northeast
f6bee Offline OP
f6bee  Offline OP
northeast
I have a fan that has seven blades and a part number (46237) Is this the proper fan for a 69 440 motor?The fan is 18 inches across and has a 1.250 spacer. Another question i have is should i go with a viscous fan.
thanks for your help
Re: fan numbers for my 69 440 [Re: f6bee] #894600
01/03/11 06:16 PM
01/03/11 06:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That is not a part number, I think it's a vendor code , if you have a big block with max cooling you are looking for the 18" 216 fan , it would more than likely be stamped in white ink .
Re: fan numbers for my 69 440 [Re: JohnRR] #894601
01/03/11 08:21 PM
01/03/11 08:21 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
This may help
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: fan numbers for my 69 440 [Re: 69CoronetRT] #894602
01/03/11 08:37 PM
01/03/11 08:37 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Sometimes the part nos is in white ink and sometimes stamped into one of the blades. If it is 18 then the number would end in "16".
