Re: Denzo Alt Wiring Help?
[Re: Pool Fixer]
#893672
01/01/11 04:39 PM
01/01/11 04:39 PM
Posts: 3,884 Oregon
hooziewhatsit
The tiny blue and green wires will go to your external voltage regulator. (assuming you have a two terminal VR, otherwise one goes to the VR, and the other you tie to ground).
The big black wire going to the case on the alt is just a good ground like you thought. With the higher amperage alts, it becomes more critical that they have a good connection to ground.
[Re: hooziewhatsit]
#893673
01/04/11 04:24 PM
01/04/11 04:24 PM
Posts: 1,374 North Central Indiana
C-Tech
Hoozie is correct, you can just wire it to a 2 wire regulator off say a 87 new yorker (lots of those in the yards) if there are issues with your current wiring.
Kevin
