A-body 8 1/4 #893639
01/01/11 03:02 PM
01/01/11 03:02 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
Could you get an A-body with an 8 1/4 with the small bolt pattern axles?
Re: A-body 8 1/4 [Re: dustergirl340] #893640
01/01/11 03:05 PM
01/01/11 03:05 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
No
Re: A-body 8 1/4 [Re: dustergirl340] #893641
01/01/11 03:17 PM
01/01/11 03:17 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
there were no small bolt pattern 8-1/4's.
Re: A-body 8 1/4 [Re: nomore65BelvJim] #893642
01/01/11 03:31 PM
01/01/11 03:31 PM
If adding an 8&1/4 to a car w SBP wheels an option would be to redrill the flanges for 7/16" studs if the center hub register dia is not a prob
Re: A-body 8 1/4 [Re: dustergirl340] #893643
01/01/11 03:39 PM
01/01/11 03:39 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
You could get the 7 1/4 with big bolt pattern or small,but 8 1/4 was only bbp.
Re: A-body 8 1/4 [Re: RapidRobert] #893644
01/01/11 04:33 PM
01/01/11 04:33 PM
hub register is the problem. Custom wheels would be required, if that would even work.
Re: A-body 8 1/4 [Re: dustergirl340] #893645
01/01/11 05:18 PM
01/01/11 05:18 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Thanks everyone!
