360-1 or -2 on a 408 stroker ? #893591
01/01/11 02:24 PM
01/01/11 02:24 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Can't seem to make up my mind ......wich one would be better for my sb stroker ?
360-1 too big port for 408 ? but more power.....?
360-2 smaller port and better velocity ?
Help me !!!!!!!
Dan
Re: 360-1 or -2 on a 408 stroker ? [Re: Wedgeman] #893592
01/01/11 02:33 PM
01/01/11 02:33 PM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
Re: 360-1 or -2 on a 408 stroker ? [Re: Crizila] #893593
01/01/11 02:35 PM
01/01/11 02:35 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Unless it is an all out effort engine (big compression, big cam, 700+ HP etc) I'd do -2's
Re: 360-1 or -2 on a 408 stroker ? [Re: RyanJ] #893594
01/01/11 02:38 PM
01/01/11 02:38 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Just out of curiousity, what kind of block will you be running and what's your horsepower target?
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: 360-1 or -2 on a 408 stroker ? [Re: ChrgrCuda] #893595
01/01/11 03:26 PM
01/01/11 03:26 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I'm running an early magnum block, and hope to achieve 575 hp
Re: 360-1 or -2 on a 408 stroker ? [Re: Wedgeman] #893596
01/01/11 03:36 PM
01/01/11 03:36 PM
SoCal
Brian Hafliger Offline
SoCal
You can get that from ported eddy magnum heads for alot less...chevy type rockers, Indy intake bolts on...
Brian
Brian Hafliger
Re: 360-1 or -2 on a 408 stroker ? [Re: Brian Hafliger] #893597
01/01/11 05:47 PM
01/01/11 05:47 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Hummmm....
Let me rephrase this, I'm shooting for 10.5 at the
track.
Are we still on the same beat with the Eddy's ?
Re: 360-1 or -2 on a 408 stroker ? [Re: Wedgeman] #893598
01/01/11 05:51 PM
01/01/11 05:51 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I would go with the indy heads, makes it much easier to reach your goal with room to grow. eddy heads your about maxed out. how heavy is your car?
Re: 360-1 or -2 on a 408 stroker ? [Re: Quicktree] #893599
01/01/11 05:54 PM
01/01/11 05:54 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
67 Barracuda with me in it ...3300 ?
Daniel
Re: 360-1 or -2 on a 408 stroker ? [Re: Wedgeman] #893600
01/01/11 06:01 PM
01/01/11 06:01 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Daniel
we run 10.40s with a stock stroke 360 with ported 1s and it's a low compression street roller motor
Re: 360-1 or -2 on a 408 stroker ? [Re: Quicktree] #893601
01/01/11 06:05 PM
01/01/11 06:05 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
A full race port or just bowl blend ?
Any specs on this street roller ?
Re: 360-1 or -2 on a 408 stroker ? [Re: Wedgeman] #893602
01/01/11 06:11 PM
01/01/11 06:11 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yes they re full race ported by Dwayne. it's a comp 308R-262@.050 575/575 a really mild cam. ran right at 130mph in the 1/4. only draw back with the fully ported one with small cubes is the lack of air speed on the off idle hit. you could probably reach your goals with out a full porting and higher compression and a bigger cam. but like they said it can be done with eddys just not a lot of room to grow. you would have to change heads if you wanted to go faster.
Re: 360-1 or -2 on a 408 stroker ? [Re: Quicktree] #893603
01/01/11 06:24 PM
01/01/11 06:24 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Low compression ? how low ?
What's the cylinder pressure ?
Dan
Re: 360-1 or -2 on a 408 stroker ? [Re: Wedgeman] #893604
01/01/11 06:43 PM
01/01/11 06:43 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
get the indys your limited with the eddys
Re: 360-1 or -2 on a 408 stroker ? [Re: one bad fish] #893605
01/01/11 06:46 PM
01/01/11 06:46 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
X2
Re: 360-1 or -2 on a 408 stroker ? [Re: Hot 340] #893606
01/01/11 06:59 PM
01/01/11 06:59 PM
SoCal
SoCal
X2
Compare cost and then make your decision. Indy is great, but really you don't want their rockers and their valves don't add much to the flow of these heads...so by the time you upgrade it aint cheap.
But hey if you gots the $$$ then yeah Indy is great way to go.
If you go with the 210 head you could always get it ported more later if you needed it which would cost you less than changing from the eddy heads to the Indy's.
Just have to figure out what YOU want...
Brian
Brian Hafliger
Re: 360-1 or -2 on a 408 stroker ? [Re: Brian Hafliger] #893607
01/01/11 07:11 PM
01/01/11 07:11 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
X2
Brian
Id buy them bare and make them how I wanted them. It is TOO expensive to buy heads right for your combination today just to rebuy everything tomorrow because you want to go faster and youve already outgrown them. Id say to the OP, if his car has gotten increasingly faster over the years, Its likely he has the et chaser bug. Buy bigger, buy once. If you can swing it.
Re: 360-1 or -2 on a 408 stroker ? [Re: Brian Hafliger] #893608
01/01/11 08:14 PM
01/01/11 08:14 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
X2
Brian
Re: 360-1 or -2 on a 408 stroker ? [Re: Wedgeman] #893609
01/01/11 08:17 PM
01/01/11 08:17 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Dan
11.5:1 cranking comp is 180
Re: 360-1 or -2 on a 408 stroker ? [Re: Quicktree] #893610
01/02/11 12:17 AM
01/02/11 12:17 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Awsome ! I was figuring 189 dynamic c.r. with my choice of parts....I guess I'm in the game!
Daniel
