Voltage limiter on guages #892817
12/31/10 07:01 PM
12/31/10 07:01 PM
Texas
70Runnerdude Offline OP
Texas
Hello I have 2 68-70 Rallye b body instrumnet clusters and on the back of them is a voltage limiter. My question is one of the voltage limiteres has the 3 terminals that plug into the circuit board the other has an extra connector on the back side of it for a wire to hook up to. What is it for ?
Thanks!
Re: Voltage limiter on guages [Re: 70Runnerdude] #892818
12/31/10 07:11 PM
12/31/10 07:11 PM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
it was for a capacitor- it was on that terminal and the case to ground- when the voltage limiter opened & closed it's contacts a nosie was generated- the radio would pick it up and you would hear it!
Re: Voltage limiter on guages [Re: 71_deputy] #892819
12/31/10 07:19 PM
12/31/10 07:19 PM
Texas
Texas
Both of my guage cluster have the capacitor on them and they plug into the middle slot of the three terminals that plug in to the circuit board. So unless there were 2 capicator wich I dont think would have the extr terminal is for what ?
Re: Voltage limiter on guages [Re: 70Runnerdude] #892820
12/31/10 07:27 PM
12/31/10 07:27 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
IF that terminl is attached to the case itself it will be an extra ground.
Re: Voltage limiter on guages [Re: stumpy] #892821
12/31/10 07:38 PM
12/31/10 07:38 PM
Texas
Texas
Its attached to the metal case of the limiter on the back of it. Why would it have a ground? Never seen one like this.
Re: Voltage limiter on guages [Re: 70Runnerdude] #892822
12/31/10 07:49 PM
12/31/10 07:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
One of the three legs is also a ground. It's just a universal fit limiter.
Re: Voltage limiter on guages [Re: stumpy] #892823
12/31/10 07:55 PM
12/31/10 07:55 PM
Texas
Texas
Thank you for the Replies Stumpy !
