340 intake suggestions #892439
12/31/10 01:33 PM
12/31/10 01:33 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I'm rebuilding a 340 and I want it to look stock when complete. It has a mild cam 202 heads and 10 to 1 compression. I have a stock intake but would like any suggestions for another dual plane mopar intake that works with the thermoquad 6318. Or should I just keep the original one on it? Thanks for the help
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: 340 intake suggestions [Re: 19cuda73] #892440
12/31/10 10:23 PM
12/31/10 10:23 PM
az
stage3 Offline
stage3  Offline
az
I always run stock intakes with my T/Q. That said I did buy a very good LD340 that I modified to fit a T/Q ..did not port match or finish. I feel from people that have run them they are one of the best dual plane intakes. Like I said I like stock intakes and if interested it's for sale.
Re: 340 intake suggestions [Re: stage3] #892441
01/01/11 02:14 AM
01/01/11 02:14 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The stock cast iron intakes flow suprisingly well, the only real drawback is weight, they are heavy suckers weighing as much or more than an iron 440 intake! As mentioned above, the Edelebrock LD340 is a good one but I'd skip right to the modern version, the Edelbrock Air Gap. the carb you have is an EXCELLENT carb, should be no worries there with a proper rebuild,
Re: 340 intake suggestions [Re: ScottSmith_Harms] #892442
01/01/11 02:53 AM
01/01/11 02:53 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
You may have to run a spacer with the air gap, i modified a 71 340 intake haven't run it yet, but i did mill the divider and slightly enlarge the plenum area, Hit all the turns trying to radius them to a nice rounded turn, then gasket matched the ports as far in as i could get with a 6" bit, also got rid of some of the lumps on the roof of the ports. Then made a larger oil splash shield for the bottom of the intake. Have about 20 hours in it and you would be surprised how much metal was removed.
Re: 340 intake suggestions [Re: ademon] #892443
01/01/11 02:54 AM
01/01/11 02:54 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
2nd
Re: 340 intake suggestions [Re: ademon] #892444
01/01/11 02:55 AM
01/01/11 02:55 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
3rd
Re: 340 intake suggestions [Re: ademon] #892445
01/01/11 02:56 AM
01/01/11 02:56 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
4th, i would at least mill the divider if its going onto a hotter mill
Re: 340 intake suggestions [Re: ademon] #892446
01/01/11 02:27 PM
01/01/11 02:27 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
What advantage to milling the divider???
Re: 340 intake suggestions [Re: JonC] #892447
01/01/11 08:09 PM
01/01/11 08:09 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
removing most of the divider was a common modification on LD340's and advised by Direct Connection back in the day. I think later LD340's came from the factory with the divider removed.
It helps performance by making the intake a little more hybrid, that is giving the dual plane manifold some single plane characteristics.
Nice modification work done on the iron intake pictured!
I've read you don't want to polish the intake ports, you want them a bit rough to help keep the fuel vapor in suspension/ atomized. Smoothing them out is fine.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 340 intake suggestions [Re: ScottSmith_Harms] #892448
01/03/11 02:19 AM
01/03/11 02:19 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Thanks for the info Will the thermoquad fit on the Air Gap?
1972 Corvette
Re: 340 intake suggestions [Re: 19cuda73] #892449
01/03/11 02:45 AM
01/03/11 02:45 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
only with an adapter..the air gap has a square bore carb flange.
Tony
70 AARCuda Vitamin C
Re: 340 intake suggestions [Re: 70AARcuda] #892450
01/03/11 05:53 PM
01/03/11 05:53 PM
P
Paul_Fancsali Offline
P
Unless your going over 7000 don't waste your time on milled divider. I have both a milled and stock and I ended up going back to divider as it will slighltly affect the low end performance. I know it will give bump less then .05 over 6000 but frankly won't run my engines over 6000 if not needed. But then agin thats my experiance and it was running with Holley Dbl pumpers not a TQ I ran a TQ for 5 years and never once got performance that a DBL pump will give but I also lost gas mileage using the dbl pumper. But frankly .4 or more in a qtr is worth it with a dbl pumper
Re: 340 intake suggestions [Re: Paul_Fancsali] #892451
01/03/11 07:24 PM
01/03/11 07:24 PM
Outside
thedriver Offline
thedriver  Offline
Outside
i always read that my air gap intake would benefit from an open 1" spacer, so i ran it that way. then one day a fellow advised me to try a 4 hole.
the tourque i picked up downlow was way more beneficial than the 6000rpm+ gain the open spacer gave me....
i guess thats why we dont race dynos tho.
1973 challenger
Dana. 4 speed. Low deck.
Re: 340 intake suggestions [Re: thedriver] #892452
01/03/11 09:03 PM
01/03/11 09:03 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
The carb spacer is another issue. Generally a 1" will help performance, but from what I read, a 4 hole spacer is usually better unless the engine is full race.
