440 Timing gear and chain install #89240
07/15/08 10:05 PM
07/15/08 10:05 PM
Middleboro,MA
Jopar Offline OP
Jopar  Offline OP
Middleboro,MA
Hello,
I was dry fitting my timing chain and noticed the crank gear does not have an interference fit onto the shaft. Is this correct I have done many small block rebuilds and don't beieve I have experienced this? Could you please help?
Re: 440 Timing gear and chain install [Re: Jopar] #89241
07/15/08 10:19 PM
07/15/08 10:19 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Sounds right to me, it shouldn't be loose once it's as far on as it can go, but it slides right on and off..
Re: 440 Timing gear and chain install [Re: Exit1965] #89242
07/15/08 10:24 PM
07/15/08 10:24 PM
Middleboro,MA
Jopar Offline OP
Jopar  Offline OP
Middleboro,MA
Thanks! I did some research and found that the damper holds it in place.
