Re: Replacing Leaf Springs
[Re: JoesMopar]
#892362
12/31/10 07:51 PM
12/31/10 07:51 PM
RapidRobert
I put a pair of stands under the rear frame rails at a pretty good height then stands under the axle tube on each side of the 3rd member (use a hyd floor jack to raise it just enough then let it back down to get the stands in there at the axles' free hanging height or a hair above) and another stand under the nose of the 8&3/4 to keep it from tipping forward and jambing the ujoint when the axle is free. Remove the 8 nuts w a nut splitter and clean the u bolt threads w a "thread chasing" die then buy 8 new grade 8 nuts (they're cheap). U bolt threads get dinged from road debris getting the orig nuts off can be a weightlifting exercise in addition to overheating/damaging the threads & w new stuff they spin on by hand if you've chased the threads. 45 ft lbs (1/2" threads). lightly snug up both sides u bolt nuts b 4 you fully tighten the u bolt nuts so the axle will be flat/not cocked up a bit and have the large thru the eye front main bolts and the rear shackle 9/16" nuts/bolts lightly snug then set it on the ground at ride height then snug them. Backing up a bit, Start the (4) nuts for the front studs just enough to hold the shackle to give you as much rearward extension as possible to make it easier to start the 2 rear bolts thru the shackle into the frame on each side. EDIT Then get these 4 corners (each shackle to the frame, not the pivot bolts/nuts) in/tight to the frame b 4 you work on the u bolts then the u bolts then set it down & final tighten the rear shackle 9/16" nuts/front thru the eye bolts/nuts
Re: Replacing Leaf Springs *DELETED*
[Re: JoesMopar]
#892363
01/10/11 11:45 AM
01/10/11 11:45 AM
Posts: 2,782 USA
JoesMopar
USA
