center link A body #891978
12/30/10 09:48 PM
12/30/10 09:48 PM
Finally a HUSKER again
Moparnut426 Offline OP
Are there 2 different center links for a bodies? I have a set of hoocker super comp headers and the hit the center link. Mine has a bend down from the where the idler and pitman goes into and drops like 3/4" if it was straight it would clear, Otherwise im gonna have to dent headers.
Kasey
Re: center link A body [Re: Moparnut426] #891979
12/30/10 09:53 PM
12/30/10 09:53 PM
okla.
sam64 Offline
sam64  Offline
okla.
for the 63-66 yes but 67 up i beleive there is just 1.
Re: center link A body [Re: sam64] #891980
12/30/10 10:04 PM
12/30/10 10:04 PM
Im kinda wondering what to do, who has the super comp headers on a stock suspension car? I dont want to dent them, but I guess I might have to. Or is there a pitman arm, and idler arm thats lower?
KAsey
Re: center link A body [Re: Moparnut426] #891981
12/30/10 11:47 PM
12/30/10 11:47 PM
I might loosen the engine mount bolts, and loosen the bolt that hold the motor mounts to the block, and see if it will drop down. I only need about 1/2 the header bolt to get them to fit. I also might take the center tubes to the press and oval the tubes at least that might make then look a little more professional.
Kasey
Re: center link A body [Re: Moparnut426] #891982
12/30/10 11:51 PM
12/30/10 11:51 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I think there is one for six cylinders and another for V8s.
Re: center link A body [Re: Darryls-Demon] #891983
12/30/10 11:54 PM
12/30/10 11:54 PM
So is the /6 version better for me and my problem??
Anyone know?
KAsey
Re: center link A body [Re: Moparnut426] #891984
12/31/10 12:00 AM
12/31/10 12:00 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: center link A body [Re: Moparnut426] #891985
12/31/10 12:23 AM
12/31/10 12:23 AM
I think the six cylinder ones are straight across and the V8 have the drop down in them, maybe vise a versa
Re: center link A body [Re: Cab_Burge] #891986
12/31/10 12:25 AM
12/31/10 12:25 AM
Id like to see a /6 bar.
Does anyone have one I can see???
Kasey
Re: center link A body [Re: Moparnut426] #891987
12/31/10 12:52 AM
12/31/10 12:52 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
LOOK AT THE LINK NEIL POSTED!
It has all the answers.
There is NO 6 cylinder centerlink after 1966 for A bodies... PERIOD!
Re: center link A body [Re: RobX4406] #891988
12/31/10 01:00 AM
12/31/10 01:00 AM
OK, so here it goes, If there isnt a straight center link, can one be made?? Can I cut and weld one? have one fabbed up? like take a chunk of round stock, and smash the ends, and drill and taper the ends?
Kasey
Re: center link A body [Re: Moparnut426] #891989
12/31/10 01:06 AM
12/31/10 01:06 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Would a straight one clear the oil pan? That bend is there for a reason, if your running an aftermarket pan its even more unlikely the straight one will work.
You can add some shims under the motor mounts maybe? It will at least help some.
68 Barracuda Formula S 340
