98 Voyager 3.0 Crank Seal Replacement? #891814
12/30/10 01:52 PM
12/30/10 01:52 PM
tboomer Offline OP
tboomer  Offline OP
I have a 98 Voyager with a 3.0 engine. Wife just had the oil changed and the mechanic said it needed a crank seal or a cam seal as it has been leaking oil. Cost for this was quoted between 300-500 bucks!! Is it that big of a job??
Re: 98 Voyager 3.0 Crank Seal Replacement? [Re: tboomer] #891815
12/30/10 02:48 PM
12/30/10 02:48 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I don't know what his labor rate is but to do just the front cam seals pays 5.2 hours and the front crank seal pays 4.3 hours. Would be a little less if all done at the same time.
Re: 98 Voyager 3.0 Crank Seal Replacement? [Re: Todd] #891816
12/30/10 02:56 PM
12/30/10 02:56 PM
tboomer Offline OP
tboomer  Offline OP
Thanks for the info...That is gonna hurt the wallet!!
Re: 98 Voyager 3.0 Crank Seal Replacement? [Re: tboomer] #891817
12/30/10 03:17 PM
12/30/10 03:17 PM
NY usa
540challenger Offline
NY usa
Is this the mitsubishi 3.0 it is a fun one. All the front accessories come off,the power steering pump has one stud/nut that is attached to a exhaust stud"it sometimes comes off" the timing cover, damper, Timing belt. just it get to the oil seal. While you are in there have him do the waterpump, new timing belt and timing belt tensionor.
Re: 98 Voyager 3.0 Crank Seal Replacement? [Re: 540challenger] #891818
12/30/10 07:22 PM
12/30/10 07:22 PM
ill
dennismopar73 Offline
ill
do the complete job
Re: 98 Voyager 3.0 Crank Seal Replacement? [Re: 540challenger] #891819
01/04/11 04:30 PM
01/04/11 04:30 PM
North Central Indiana
C-Tech Offline
C-Tech  Offline
unfourtunatly I have to agree, to bad you dont live closer I would help you do it it is not that hard just a lot to do.
Kevin
Re: 98 Voyager 3.0 Crank Seal Replacement? [Re: C-Tech] #891820
01/04/11 04:34 PM
01/04/11 04:34 PM
tboomer Offline OP
tboomer  Offline OP
Thanks,guys!! The darned thing runs good...I hate to junk it because of an oil leak!! It gets good mileage,too!
