Can I Swap an E-body rear into a B? #891625
12/30/10 04:04 AM
12/30/10 04:04 AM
AZ
2
2ndopp Offline OP
2ndopp  Offline OP
AZ
I have a 1973 Plymouth Satellite 360 with a 727 trans and 8 1/4 rearend
Would a 8 3/4 from a 1972 Cuda with Moser axles and 5/8 studs, 241 case bolt in?
Re: Can I Swap an E-body rear into a B? [Re: 2ndopp] #891626
12/30/10 04:34 AM
12/30/10 04:34 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Re: Can I Swap an E-body rear into a B? [Re: 2ndopp] #891627
12/30/10 05:16 AM
12/30/10 05:16 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
No, it will not "bolt-in".
But it would not take a lot to make to fit and work properly.
Re: Can I Swap an E-body rear into a B? [Re: ProStDodge] #891628
12/30/10 05:26 AM
12/30/10 05:26 AM
AZ
2
2ndopp Offline OP
2ndopp  Offline OP
AZ
Thanks for the quick replies
I see that my B-body has a 63" wide rear and the E has 61 5/8" (drum to drum) and the chart shows even more:
Re: Can I Swap an E-body rear into a B? [Re: 2ndopp] #891629
12/30/10 06:49 AM
12/30/10 06:49 AM
Hotwheelsjr Offline
Hotwheelsjr  Offline
Right -- so with the E-body rear, if you use wheels with 3/4" less of backspace (to make up the overall 1.5" of lost width), it will work. You would also have to relocate your spring perches to match the B-body spring width. Lastly, going from a 8 1/4 to a 8 3/4 will require a driveshaft that is 2/3" shorter -- in other words, the 8 3/4 shortens the distance between your tranny and the rear's yoke. The current 8 1/4 driveshaft may work, but it also may bottom out in your tranny and be too long.
Re: Can I Swap an E-body rear into a B? [Re: Hotwheelsjr] #891630
12/30/10 11:41 AM
12/30/10 11:41 AM
scratchnfotraction Offline
one of those charts in the archives is wrong..IIRC its the one posted above
make sure you use the right one and get the correct measurements
Re: Can I Swap an E-body rear into a B? [Re: scratchnfotraction] #891631
12/30/10 02:16 PM
12/30/10 02:16 PM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
66-67 B-Dana 60 is 3/4" narrower than a 68-70 B-Dana. The chart above is incorrect on this
Re: Can I Swap an E-body rear into a B? [Re: Hemidavey] #891632
12/30/10 03:26 PM
12/30/10 03:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Same is true for a 8 3/4 in the 66-67 B body
