360 to 318 accessory belt interchange #891557
12/29/10 11:39 PM
12/29/10 11:39 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I'm changing from a 318 to a 360 and i swapped over all the pulleys and brackets from the 318 to the 360, but the belts all seem too long now. Is that normal? I figured the 318 belts would work. Am I going crazy or do I have somethongbolted on or aligned wrong. If anyone has pics of a LA 360 with all brackets set up that would be helpful.Car has a/c and power steering.
thanks
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: 360 to 318 accessory belt interchange [Re: roe] #891558
12/29/10 11:49 PM
12/29/10 11:49 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
should be identical. i went from a 318 to 360 and everything fit perfect. As far as accessories go, there is no difference between the two.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: 360 to 318 accessory belt interchange [Re: goldduster318] #891559
12/30/10 01:15 AM
12/30/10 01:15 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
You know, I think I figured it out. The 360 had a non-a/c water pump, and i didn't swap it out for my "with" a/c water pump. It's the only piece I didn't swap out, and it looks like it will raise the location of the a/c compressor and tighten up the slack. I'll try it tomorrow.
roe
Re: 360 to 318 accessory belt interchange [Re: roe] #891560
12/30/10 11:48 AM
12/30/10 11:48 AM
scratchnfotraction Offline
water pump is a water pump
the a/c and non a/c deal is all in the pulleys
if you used all the 318 pullys on the 360 it should go back together as it was
if the belts are too long now,something is out of adjustment or not mounted correct position
post a couple pics of what you have mounted up so we can see
it should be fairly ez to set up...just need a looky see at it
Re: 360 to 318 accessory belt interchange [Re: scratchnfotraction] #891561
12/30/10 12:32 PM
12/30/10 12:32 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
Double check your alternator brackets.... I had the same problem and it was in that area somewhere. It's been a few years, I don't remember exactly what, but I had the a bolt in the wrong hole on the alternator bracket, and even went to the parts store to order shorter belts before I figured it out.
The Blue Goose
My instagram: Bossride
Re: 360 to 318 accessory belt interchange [Re: BossRide] #891562
12/30/10 03:33 PM
12/30/10 03:33 PM
Löffingen, Germany
The_Mean_Machine Offline
Löffingen, Germany
318 brackets bolted to a 360 Magnum:
Re: 360 to 318 accessory belt interchange [Re: The_Mean_Machine] #891563
12/30/10 06:06 PM
12/30/10 06:06 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
thank very much guys
