thread contact #891296
12/29/10 05:25 PM
12/29/10 05:25 PM
Finally a HUSKER again
Moparnut426 Offline OP
So what is a known good thread count sticking out from the heads? Ive never used bolts, and I have ARP bolts for eddy heads, and they look short, but I might just not know what is normal for bolts. I have 3/4" of threads out the bottom of the head. Its accually only .618" with a washer and no head gasket.
And for you guys wondering, YES I am a very questioning person. It just looked short to me.
Kasey
Re: thread contact [Re: Moparnut426] #891297
12/29/10 07:51 PM
12/29/10 07:51 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
length =
1 X Dia for Steel*
1.5 X Dia for Iron*,
2 X Dia for Alu/brass*
(*material that the fastener will thread into)
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: thread contact [Re: W.I.N. Racing] #891298
12/29/10 08:32 PM
12/29/10 08:32 PM
I just spoke with ARP, and they use the same bolt kit length wise for the eddy heads, and stock cast heads, and if you go to studs, they are longer and 2 different kits. I had him give me lengths for both bolts kit, and they were the same.
