68 Barracuda Rocker Panel (spear) molding clip ???? #891226
12/29/10 01:05 PM
12/29/10 01:05 PM
Russ H. Offline OP
Russ H.  Offline OP
I am looking for a picture of an original clip that was used to attach the rocker panel spear molding to a 68 Barracuda. I am assuming these are no longer available or reproduced. If so, what is being used in place of the original type clips?
Russ
Re: 68 Barracuda Rocker Panel (spear) molding clip ???? [Re: Russ H.] #891227
12/30/10 01:09 PM
12/30/10 01:09 PM
Russ H. Offline OP
Russ H.  Offline OP
Anyone?
Re: 68 Barracuda Rocker Panel (spear) molding clip ???? [Re: Russ H.] #891228
12/30/10 01:35 PM
12/30/10 01:35 PM
cali
68mannix Offline
68mannix  Offline
cali
if its like the 69 dart gts spear they sell plastic repos that i couldnt get to work, so i went to local auto paint supply and bought some metal spring clips that work great.
Re: 68 Barracuda Rocker Panel (spear) molding clip ???? [Re: 68mannix] #891229
12/30/10 03:04 PM
12/30/10 03:04 PM
Russ H. Offline OP
Russ H.  Offline OP
Is the 69 Dart trim a thin spear, about 3/4 of an inch tall? I too, bought the plastic repro clips and do not think they will work. Also, can you post a picture of the metal spring clip??
Thank you,
Russ
Re: 68 Barracuda Rocker Panel (spear) molding clip ???? [Re: Russ H.] #891230
12/31/10 03:12 AM
12/31/10 03:12 AM
cali
68mannix Offline
68mannix  Offline
cali
the dart ones are about 3/4 wide,ill have to look for a clip to take a picture off,those cheap plastic repos are long enough to snap into the rocker.
Re: 68 Barracuda Rocker Panel (spear) molding clip ???? [Re: 68mannix] #891231
12/31/10 05:02 AM
12/31/10 05:02 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I just went in the garage and measured for you. I have the original spears on my 68 Cuda and have a set of primo used spears I got at last Fall Fling that I have started sanding and polishing allready.
The O.D. measure:
Dart Rocker Spear: 0.74"
68 Barracuda Rocker Spear: 0.82"
Re: 68 Barracuda Rocker Panel (spear) molding clip ???? [Re: autoxcuda] #891232
12/31/10 12:36 PM
12/31/10 12:36 PM
Russ H. Offline OP
Russ H.  Offline OP
Autoxcuda,
Thank you for the measurement. It would be much appreciated if you would measure the inside channel where the clips sit. (I don't presently have access to mine, they were sent out for re-finishing.
Thank you,
Russ
Re: 68 Barracuda Rocker Panel (spear) molding clip ???? [Re: Russ H.] #891233
12/31/10 02:02 PM
12/31/10 02:02 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Autoxcuda,
Thank you,
Russ
My cuda spears on installed on the car. Do you want the Dart measurement?
Re: 68 Barracuda Rocker Panel (spear) molding clip ???? [Re: autoxcuda] #891234
12/31/10 03:49 PM
12/31/10 03:49 PM
Russ H. Offline OP
Russ H.  Offline OP
Autoxcuda,
Thank you,
Russ
No, but thank you for the offer, I appreciate your help.
Russ
Re: 68 Barracuda Rocker Panel (spear) molding clip ???? [Re: Russ H.] #891235
12/31/10 06:39 PM
12/31/10 06:39 PM
Oahu, Hawaii
P
ParadiseCuda Offline
P
Oahu, Hawaii
I made a couple fo pictures of the clip that I took off of my 68 FB spears.
