Question about Solid Motor Mounts #891222
12/29/10 01:04 PM
12/29/10 01:04 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I had solid motor mounts in my 67 440 Coronet RT. I noticed that the engine sat cradled on the K-frame about an 1" higher than with stock mounts. Would this effect the geometry of the drive-line? Pinion angle etc. Thanks.
RS23L7 4-Speed
Re: Question about Solid Motor Mounts [Re: Mopar_Mike] #891223
12/29/10 01:41 PM
12/29/10 01:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It will make a bit of difference but not much...you
can figure it with math(if you want)... being that
the trans mount is the same place its pivoting on that
point so the tail shaft will be a bit lower
Re: Question about Solid Motor Mounts [Re: Mopar_Mike] #891224
12/29/10 02:45 PM
12/29/10 02:45 PM
organ
maximum entropy Offline
organ
i'd measure it with an angle finder, just to be sure. adjust as necessary. it shouldn't be a big deal.
Re: Question about Solid Motor Mounts [Re: maximum entropy] #891225
12/29/10 03:10 PM
12/29/10 03:10 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Unless they were home made solid mounts , all the boughten ones that I have seen were the same thickness as the rubber mounts, I believe I had Moroso ones , they were direct replacements . Were your original ones broken?
