Drag link question E body #89063
07/15/08 05:22 PM
07/15/08 05:22 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
what way does the drag link go on in a E body? mine doesnt look right?any pictures?it sure makes the tie rod end close to the torsion bar when going past.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Drag link question E body [Re: hulmule] #89064
07/15/08 06:34 PM
07/15/08 06:34 PM
i'd assume that it only will go in one way because of the taper in the holes have to fit the taper in the pitman arm and idle arm.
Re: Drag link question E body #89065
07/15/08 09:16 PM
07/15/08 09:16 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
yea but wouldnt those be the same holes if it was turned end to end??its off set one way
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Drag link question E body [Re: hulmule] #89066
07/16/08 07:15 PM
07/16/08 07:15 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
any help guys?
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Drag link question E body [Re: hulmule] #89067
07/16/08 07:58 PM
07/16/08 07:58 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Technically, a vintage Mopar such as your Challenger has a center link, with the term drag link usually reserved for steering linkages lacking an idler arm. In those setups, the drag link connects directly from the pitman arm to a steering knuckle, with a really long tie rod then going over to the other side.
Now that the picking of nits has been put aside, to your question:
I suppose there are four orientations in which one could try to install a center link. Two of them would be immediately ruled out (as was pointed out previously) by the tapered nature of the attaching components. Of the remaining two possible orientations, the "drop" in the center being slightly down and to the rear (to clear oil pans and the like) is the correct one.
Although there is no interference, the inner tie rod end on the left side passes pretty close to the t-bar on my 1970 'vert (if it's any consolation to you).
Down to just a blue car now.
