Ring gaps for my 452 #890099
12/28/10 12:59 PM
12/28/10 12:59 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
This is the first time my engine will have been assembled w/ conventional file-fit rings since it was built waaaaay back w/ "gapless" stuff. The PBM-branded rings supplied by the local machine shop that did the re-hone on the cylinders are plasma-moly / reverse back-twist / standard oil tension in the 1/16", 1/16", 3/16" size.
I don't know if I should consider my combination "moderate" or "serious" for gapping purposes. Moderate would use .004 top / .005 2nd per inch of bore diameter vs. .0045 top / .0055 2nd. For a 4.380" bore, that works out to...
Top --> .004 = .018"; .0045 = .020"
2nd --> .005 = .022"; .0055 = .024"
Engine will be spun up to 7K RPM and run w/ 10.8 CR on 93-octane pump gas. Also, the top ring position is .175" below the deck.
Guidance requested.
Re: Ring gaps for my 452 [Re: BradH] #890100
12/28/10 01:05 PM
12/28/10 01:05 PM
NC
440Jim Offline
440Jim  Offline
NC
Guidance requested.
My 2-cents. There isn't really anything significant to gain with tight ring gaps. It should be fine either way, but for high heat insurance, I would go about:
Top: 0.019-0.020"
2nd: 0.022-0.023"
My engine (higher CR, hp, etc) is 0.021", and 0.024" as I recall.
Re: Ring gaps for my 452 [Re: 440Jim] #890101
12/28/10 01:34 PM
12/28/10 01:34 PM
UK
602heavy Offline
602heavy  Offline
UK
Here's my camp............
Top......0045 X bore=.020"
Second...0045 X bore=.020"...............top ring will 'see' more heat than second , added bonus being 2nd cast ring will wear faster than steel top.............
await the shooting match.
Re: Ring gaps for my 452 [Re: BradH] #890102
12/28/10 02:56 PM
12/28/10 02:56 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use .020 to .024 on the tops and .024 to .028 on the second rings on all of my builds now since 2001 or so Way better to have enough or a little to much end clearances than not quite enough, especially if you get the hankering for some squeeze or other power adders later
Re: Ring gaps for my 452 [Re: Cab_Burge] #890103
12/28/10 03:00 PM
12/28/10 03:00 PM
UK
602heavy Offline
602heavy  Offline
UK
Well , lets gap em .007 right off the bat then. ........better steer clear of the molly type rings too.
