stage vi heads #890021
12/28/10 01:55 AM
12/28/10 01:55 AM
iowa
rook440 Offline OP
rook440  Offline OP
iowa
whats the best way to restrict the oil with stage vi heads ..seems like they hold a pint of oil under each valve cover and make a mess when you have to set the roller lifter lash .....any Ideas?????
Re: stage vi heads [Re: rook440] #890022
12/28/10 02:12 AM
12/28/10 02:12 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I cut my spring pockets down so that all the oil can drain down into the pan.when I remove my valve covers I only get a little oil at the rear of the heads..Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
