oil pump #890012
12/28/10 01:14 AM
12/28/10 01:14 AM
Ohio
jhoward Offline OP
jhoward  Offline OP
Ohio
What's up with a oil gauge that fluctuates on a 03 ram 1500? Is it bad or is the sending unit bad? Thanks
Re: oil pump [Re: jhoward] #890013
12/28/10 01:19 AM
12/28/10 01:19 AM
shavertown pa.
K
kbeeper69 Offline
kbeeper69  Offline
K
shavertown pa.
try a mechanical guage before anything.
Re: oil pump [Re: kbeeper69] #890014
12/28/10 10:05 PM
12/28/10 10:05 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Might be a flash for the pcm for this issue depending on the the engine. seems like I have seen a few TSBs on this. I wouldn't put much faith in a factory oil pressure gauge anyway. Like previously mentioned, always check with a mechanical gauge to be sure if there is a problem.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
