Re: Guys with Strange struts and spindle mount front wheels
[Re: silverfish]
#889801
12/27/10 08:14 PM
12/27/10 08:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont have the spindle struts but I have the fixed position dynomites... it uses a cross over tube so both pads move together... I get as much braking as my tires can handle
[Re: MR_P_BODY]
#889802
12/28/10 12:28 PM
12/28/10 12:28 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Not aware of any "kits" out there that incorporate anything other than the single piston caliper.
[Re: Al_Alguire]
#889803
12/28/10 12:40 PM
12/28/10 12:40 PM
Posts: 858 Oklahoma
silverfish
Oklahoma
Do you have the Strange setup on your car?
[Re: silverfish]
#889804
12/28/10 12:48 PM
12/28/10 12:48 PM
Al_Alguire
Las Vegas
Yes I do. But I went with a non spindle mount set up. Like the spindle mount wheels more but did not like the brake options with my heavy car.
[Re: Al_Alguire]
#889805
12/28/10 01:05 PM
12/28/10 01:05 PM
Posts: 858 Oklahoma
silverfish
Oklahoma
Well my car is light, 2250# without me, but it still doesn't feel right to me. Matter of fact, it won't even hold still with the linelock on in the driveway. This setup was already on the car when I bought it. I'm wondering if maybe something is plumbed wrong? I don't know anything about brake systems, never really messed with them. I've bled these to make sure there wasn't any air in the lines and everything seemed fine. They seem to have plenty of pressure at the calipers although I don't have a gauge on them to know exactly how much. I can put a second caliper on each side because my spindles have the mounts on both sides of the strut so maybe that would help?
[Re: silverfish]
#889806
12/28/10 01:10 PM
12/28/10 01:10 PM
MR_P_BODY
Do you have a adjustable prop valve on them....I had to really cook the fronts so they became effective... just dont over heat the rotors
[Re: MR_P_BODY]
#889807
12/28/10 01:20 PM
12/28/10 01:20 PM
Posts: 858 Oklahoma
silverfish
Oklahoma
Yes there is a prop valve and it is screwed all the way in. I believe that means it is giving full pressure to them right?
[Re: silverfish]
#889808
12/28/10 01:38 PM
12/28/10 01:38 PM
Posts: 858 Oklahoma
silverfish
Oklahoma
Correction: I just went to the shop and checked and the prop valve is on the rear brake line not the front but it is screwed all the way in. So if I understand the system correctly that means I've got full pressure to the front brakes if there is no prop valve on them right? It also means that I've got full pressure to the rear brakes if the prop valve is screwed all the in correct?
The front brake line runs from master cylinder to the line lock and then out from it to a tee and of course then to both sides of the front brakes. Could something be wrong with the linelock that would cause the front brakes to not work correctly?
[Re: silverfish]
#889809
12/28/10 02:03 PM
12/28/10 02:03 PM
Posts: 2,113 Byron, NY
W.I.N. Racing
Byron, NY
It is possible you have too large a diameter master cyl. Do you know what Dia the piston is in your master cyl? typicaly you would want a 3/4" diameter
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#889810
12/28/10 02:21 PM
12/28/10 02:21 PM
Posts: 858 Oklahoma
silverfish
Oklahoma
No I don't know that info. It looks to be a Strange master cylinder. I am assuming that when the car was built this was all bought and installed at the same time. So I'm going to assume its a Strange master cylinder but not sure of the piston diameter.
[Re: silverfish]
#889811
12/28/10 03:40 PM
12/28/10 03:40 PM
MR_P_BODY
From the way it sounds your doing ALL of your braking with the front tires... open up the prop valve so the rears are doing MOST of the work(if this is a big tire race car)
[Re: MR_P_BODY]
#889812
12/28/10 03:42 PM
12/28/10 03:42 PM
Posts: 858 Oklahoma
silverfish
Oklahoma
Yes its a big tire Top Sportsman car 33.5 x 16.5 tires. I was under the impression that if the prop valve is screwed all the way in that gives full pressure to the rear tires? Is that not correct? If thats not correct then I am definitely not giving my back tires any pressure because the valve is screwed in as far as it will go!
[Re: silverfish]
#889813
12/28/10 03:53 PM
12/28/10 03:53 PM
MR_P_BODY
On mine its just the opposite from what you have... plus mine is on the fronts.... a prop valve is meant to slow the fluid on a spike but it will balance out after X period of time.... you know that the fronts cant brake as much as the rears just due to the size and a race car doesnt dive like a street car
[Re: go green]
#889815
12/29/10 02:32 AM
12/29/10 02:32 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
where does the line come off of the master cylinder that is going to the front brakes???It should be the one closest to the mounting flange. If that is correct next we need to know the brake pedal ratio. I have that same brake setup on a 3000lb bracket car that runs 160 and has never pulled the chute.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: go green]
#889816
12/29/10 02:39 AM
12/29/10 02:39 AM
Posts: 858 Oklahoma
silverfish
Oklahoma
Went through the same hassle and did allot of head scratching.
I had the 4 piston calipers on the fronts and they held in the burnout box easy. Then I changed to the single piston calipers for the spindle mount wheels and it would push forward on the burnout.
I have to make sure I pump the brakes and trap at least 1000 psi on the line lock and it will hold . I have a 3/4 master cylinder on the front and a 7/8 master cylinder on the back running dual 4 piston calipers
How does it do on stopping power at the top end? Are you running two separate master cylinders?
I ran it like this when i had a 750hp motor and it was no big deal. Now i have a 1100hp motor and plan to run nitrous also so it becomes a whole different story. I chose to not go test with it when i had the chance a month or so ago because i was scared of these front brakes! I just want to make sure everything is right before i go to the track with it. I guess i need to get a pressure gauge and see what ive got there.
[Re: bigtimeauto]
#889817
12/29/10 02:46 AM
12/29/10 02:46 AM
Posts: 858 Oklahoma
silverfish
Oklahoma
Not sure on that one without looking at it. I will look at it tomorrow and see. How do i measure brake pedal ratio? That kind od stopping power is what I'm looking for. Dont wanna mess with the chute unless I have to. And I wont ever race it on the 1/4 just 1/8 so probably 145-150mph will be where I plan on being with this car on the 1/8. I feel like an idiot not knowing anything about this stuff but I just havent ever messed with brakes.
[Re: go green]
#889819
12/29/10 12:17 PM
12/29/10 12:17 PM
Posts: 858 Oklahoma
silverfish
Oklahoma
