A833OD Shifting issues #88964
07/15/08 01:39 PM
07/15/08 01:39 PM
Mass
dgc333 Offline OP
dgc333  Offline OP
Mass
I have an A833OD 4spd behind a 360 in my 68 Barraucda. This tranny has been in use for the past 50k miles in the car, initially behind a \6 and now for the past 21k miles a 360.
The tranny has never been a slick shifting unit but over the past few days getting it into 1st or reverse after it's been driven for awhile has gotten really tough and it won't go into reverse with out some gear grinding. A 1-2 is OK and 2-3 or 3-4 does not seem to be impacted at all.
First thing in the morning it's fine and it progressively gets worse the more you drive. I though maybe the clutch was dragging ( and it still may be) but I did adjust as much of the slop out of the pedal as possible and it didn't improve the situation.
When I got the tranny it had ATF in it. When I installed it in the Barracuda 50k miles ago
I put synthetic gear oil in it and it would grind in every gear. I immedaitaely replaced the syntetic gear oil with ATF and it's had the ATF until last year when I swapped in Penzoil Syncromesh manual transmission fluid. At the time it was an improvement over the ATF in shift quality.
Anyone got any ideas what might be causing the difficulty going into 1st and reverse when hot?
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: A833OD Shifting issues [Re: dgc333] #88965
07/15/08 02:01 PM
07/15/08 02:01 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It's almost certainly a dragging input shaft, either from the clutch, pilot bushing/bearing, or ?? Pull the inspection cover and see what things look like. I suspect that the trans will be coming out soon, though.
Re: A833OD Shifting issues [Re: Jim_Lusk] #88966
07/15/08 03:09 PM
07/15/08 03:09 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I agree with Jim, make sure the clutch is dissengaging enough by maintaing proper free play.
MM
Re: A833OD Shifting issues [Re: 500ciDuster] #88967
07/15/08 03:54 PM
07/15/08 03:54 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
you ansered half of your own question yourself. you used synthetic to start with, had problems. switched to ATF, no probs. went to another synt and have probs again.. DUH...
a few years ago I rebuilt 2 OD 833s for a friends 2 Feather Dusters. 1 had ATF put in it. somebody told him to use Mobil 1 synt in the second, it was almost impossible to shift when cold. changed to to ATF, no more problems.
evidently the synt doesnt let the syncro rings float and thats where the grinding comes from.
change bact to ATF, maybe that will help. if not the syncro rings are worn and need replaced
hows the fluid level? is it low?
I am truckless..
Re: A833OD Shifting issues [Re: Jim_Lusk] #88968
07/15/08 05:00 PM
07/15/08 05:00 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
w/Jim.
Swapping fluids is only masking an evident internal problem.
Re: A833OD Shifting issues [Re: Pntastar69] #88969
07/15/08 06:08 PM
07/15/08 06:08 PM
Chicagoland
chargerron69 Offline
Chicagoland
i know this maybe alittle O/T but is it ok to run regular 80/90 gear lube in one? thanks
Ron
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: A833OD Shifting issues [Re: dgc333] #88970
07/15/08 06:46 PM
07/15/08 06:46 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
grinding going into reverse is some kind of clutch disengagement issue and NOT a fluid issue since reverse is non-synchronized. Check the air gap between the clutch disc and flywheel with the clutch pedal to the floor and go from there. It should have a .040-.050" gap.
Re: A833OD Shifting issues [Re: 340SHORTY] #88971
07/15/08 06:50 PM
07/15/08 06:50 PM
Mass
dgc333 Offline OP
dgc333  Offline OP
Mass
Penzoil Syncromesh manual tranny fluid is not a synthetic and it specifically states it's compatable with yellow metal syncros used in chrysler trannies, it falls under the general heading of gear oils on the Penzoil web page. Plus it made an improvement in the shifting when I swapped it in over 10k miles ago and the problem I am having has just started in the past few days. I gave the oil history just so the brain trust on Moparts would have some history of the tranny.
I tend to believe the clutch is dragging or the input shaft is sticking in the pilot bushing. I posted this just to get a sanity check before pulling the tranny. But I will definately pull the inspection cover and take a look at the gap first.
I really appreciate the inputs.
Re: A833OD Shifting issues [Re: dgc333] #88972
07/15/08 10:59 PM
07/15/08 10:59 PM
dogdays Offline
dogdays  Offline
Check clutch disengagement first.
R.
Re: A833OD Shifting issues [Re: chargerron69] #88973
07/15/08 11:54 PM
07/15/08 11:54 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Ron
Sure is. I run it in both of my A-833s.
Re: A833OD Shifting issues [Re: In_The_Pink] #88974
07/16/08 07:03 AM
07/16/08 07:03 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Just bought some Mobile1 in the lighter weight. Was told Castrol Syntorque was good. They didn't sell it locally.
My Prothane mount got here yesterday from www.magnumhp.com in she goes tonight!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: A833OD Shifting issues (Update) [Re: dgc333] #88975
07/20/08 01:23 PM
07/20/08 01:23 PM
Mass
dgc333 Offline OP
dgc333  Offline OP
Mass
Well I dropped the inspection cover and didn't see anything out of the ordinary. There was adequate travel and the disk spun freely when the pedal was on the floor. I had re-gasketed the tranny over the winter because of some leaks around the shift shafts and speedo adapter and there was no signs of leaking but I checked the fluid anyway and it was right up there.
I took it for a drive and it was shifting like it had before. When I got back and went to back the car into the garage it was balking about going into reverse again. Then all of a sudden something popped and the car lurched. I though the linkage had come off but everthing was in place and moving but there is no resistance in the pedal.
I just ordered a new clutch and it will be clutch replacement time this week!
Re: A833OD Shifting issues (Update) [Re: dgc333] #88976
07/25/08 08:32 AM
07/25/08 08:32 AM
Mass
dgc333 Offline OP
dgc333  Offline OP
Mass
Well I have it apart! The piece that the release finger hangs on and provides the pivot the finger rotates on broke.
It looks like a forged piece and has a large buldge in the middle with a hole for the pivot pin. It cracked through that area and opened slightly. I would say that accounts for the sudden in ability to shift into reverse. The pop I heard and the loss of all clutch release was when the threaded area of this piece broke where it threads into the adjusting nut that is on the outside of the pressure plate housing. This allowed one of the fingers to float around and not provide for any release.
The other interesting thing. I always had to keep the clutch adjusted loose or when the pedal was on the floor the fingers would contact the springs in the disk. The hub area of the disk was about 1/2 to 5/8" higher than the surface of the friction material. The new clutch disk the hub area is only a 1/4" higher than the friction material. Looks like I won't have the issue of the fingers contacting the springs with the new clutch.
FWIW, the failed clutch had 22k miles on it and was a ZOOM OE Replacement clutch. The new one is a RAM Muscle Car clutch that is rated up to 500 HP. The RAM pressure plate has clamping springs with larger diamter wire and the the piece the fingers pivot on is much larger in diameter. The disk has a thinner hub area and the and the cush springs have a smaller OD with larger diameter wire. There is also a wave spring between the two sides of friction material that the ZOOM did not have.
Re: A833OD Shifting issues (Update) [Re: dgc333] #88977
07/28/08 10:08 AM
07/28/08 10:08 AM
Mass
dgc333 Offline OP
dgc333  Offline OP
Mass
Well the new clutch is in and the action is greatly improved over the previous one. I can also adjust the clutch to the proper throw out bearing clearance and not have to worry about pushing the fingers into the disk.
The new clutch is a performance clutch rated to 500 HP and is stiffer but not dramtically and I wouldn't think twice about it if I had installed that one in the first place.
Re: A833OD Shifting issues (Update) [Re: dgc333] #88978
07/28/08 11:27 AM
07/28/08 11:27 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
did all 833od use trans fluid? i took one out of an 81 truck that had gear oil and one out of an 86 truck that had trans fluid. what year did they change over?
Re: A833OD Shifting issues (Update) [Re: 65rbdodge] #88979
07/28/08 04:22 PM
07/28/08 04:22 PM
Mass
dgc333 Offline OP
dgc333  Offline OP
Mass
Don't know what years used what but I do recall reading that there was a TSB that said to replace the ATF with gear oil if the customer complained of gear noise in neutral. I know mine makes quite a bit of noise in neutral with the clutch engaged and engine idling that it does not make in gear or even in neutral when the clutch is disengaged.
FWIW, I used 75W-90 gear oil when I filled it this time because the local Autozone didn't have enough of the Penzoil Syncromesh fluid. It is quieter in neutral.
