Holley 3barrel Carb? #88940
07/15/08 11:56 AM
07/15/08 11:56 AM
Oh
RacerGofKGB Offline OP
Got The Big One
Got The Big One
Oh
Anybody still use one? I have been looking for a carb for my street/strip car and have come across a few . just curious as to what would be expected from one.
Re: Holley 3barrel Carb? [Re: RacerGofKGB] #88941
07/15/08 12:02 PM
07/15/08 12:02 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I had one. saw no difference. If they were an edge everyone would have one and the would be popular.
Re: Holley 3barrel Carb? [Re: NITROUSN] #88942
07/15/08 12:05 PM
07/15/08 12:05 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
buddy had one on his Chevelle, couldn't tell any difference performance wise from a 4 barrel. It was a big carb though, like 950 cfm......
Re: Holley 3barrel Carb? [Re: RacerGofKGB] #88943
07/15/08 12:10 PM
07/15/08 12:10 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
don't see why it wouldn't work just as good as a 4bbl. The rear butterflies have just been coverter to one single flap. Just make sure it will work on your intake. That rear door night get hung up on a standard 4 hole or dual plane intake.
Re: Holley 3barrel Carb? [Re: RacerGofKGB] #88944
07/15/08 08:02 PM
07/15/08 08:02 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Try to get the mark II version with 1050 CFM. It had revised secondary metering to fix a lean tip in stumble on the smaller 950. Most of the early intakes were already notched to clear the butterfly.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Holley 3barrel Carb? [Re: gamagoat6x6] #88945
07/15/08 08:39 PM
07/15/08 08:39 PM
Oh
Got The Big One
Got The Big One
Oh
I have a single plane intake, so there shouldnt be an issue there. Are there any performance upgrades available for these carbs? Do any parts interchange with the standard 4150 style carb?
Re: Holley 3barrel Carb? [Re: RacerGofKGB] #88946
07/15/08 08:56 PM
07/15/08 08:56 PM
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
The front half is identical to the 850 four barrel so jets and stuff are all interchangeable. They`re 3160 carbs so the secondary side has a metering plate with drilled jets like all the 60 series holleys and you can NOT swap it over to a metering block because the booster feeds are closer together than the four barrels.
Re: Holley 3barrel Carb? [Re: Mr.Yuck] #88947
07/15/08 10:20 PM
07/15/08 10:20 PM
obviously you never tried one. it has horrible street manners. sec.vac signal is weak, an all-round dog
of a carb.
Re: Holley 3barrel Carb? #88948
07/16/08 07:03 AM
07/16/08 07:03 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
of a carb.
nope never have, but then again I stay away from vacuum carbs anyway.
Re: Holley 3barrel Carb? [Re: Mr.Yuck] #88949
07/16/08 07:05 AM
07/16/08 07:05 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Weren't these a "loop hole" carb for Pontiacs in NASCAR?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Holley 3barrel Carb? [Re: Rug_Trucker] #88950
07/16/08 11:17 AM
07/16/08 11:17 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I believe they were used in NASCAR, I know Motion performance used them. Here is how to make them really work. I dont think these parts are made anymore but if you can find them they do work. Im going to go through this one and put it back in service soon. Take the vacume pod off, add the gears to the linkage and the accelerator pump nozzels to the rear.
1969 Hemi Roadrunner 2nd owner
Re: Holley 3barrel Carb? [Re: 69hemibeep] #88951
07/16/08 11:18 AM
07/16/08 11:18 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
2
Re: Holley 3barrel Carb? [Re: 69hemibeep] #88952
07/16/08 12:46 PM
07/16/08 12:46 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
There's a write-up in the Holley manual against using those gears on carbs.
Thier reasoning is that they will bind up over time and that could be when your at full throttle
Re: Holley 3barrel Carb? [Re: 76Beeper] #88953
07/16/08 01:24 PM
07/16/08 01:24 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Full throttle is where it usually is,used it for years with no issues. I better keep the kill switch handy!
Re: Holley 3barrel Carb? [Re: 76Beeper] #88954
07/16/08 02:27 PM
07/16/08 02:27 PM
Oh
Got The Big One
Got The Big One
Oh
Just a thought... Those gears look to be 1:1, so im sure a simple linkage could be made to do the same thing in place of the gears.
Re: Holley 3barrel Carb? [Re: RacerGofKGB] #88955
07/16/08 07:34 PM
07/16/08 07:34 PM
just a thought... those carbs are not worth doing period.
Re: Holley 3barrel Carb? #88956
07/17/08 12:29 AM
07/17/08 12:29 AM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
I had one, just looked at my Holley stash, must have sold it. Did find a really great small block bracket carb I forgot I had though, a 780 vacuum secondary double pumper. I think they only made these for a little over a year sometime in the mid 70s.
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: Holley 3barrel Carb? [Re: GTX70sixpack] #88957
07/17/08 05:21 AM
07/17/08 05:21 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
They work good. I still have a Car Craft mag from around 1970 where they took a Baldwin Motion 69 Camaro with their warmed over 427 with headers and did a swap from a 780 vac Holley to the 3 barrel carb that was an 850 I believe and it went from 11.90's to 11.60's. That carb was used a good bit back in the 70's and worked good. Ron
Re: Holley 3barrel Carb? [Re: 383man] #88958
07/17/08 08:58 AM
07/17/08 08:58 AM
shavertown pa.
K
kbeeper69 Offline
kbeeper69  Offline
K
shavertown pa.
i have a 950 on my 440 now. more responsive than my 850 double pumper. also my brother has the 1050 cfm with the gears and the shooters for the secondarys,on his 455 buick..
Re: Holley 3barrel Carb? [Re: kbeeper69] #88959
07/17/08 10:13 AM
07/17/08 10:13 AM
right between milan dragway & ...
Flite_727 Offline
Flite_727  Offline
i had one on my street/strip, mild 440 powered 4000 lb.'82 D-150, it ran flawless high 11's on pump gas through the mufflers on ET streets.(best of 11:69 @ 112 with a 1.59 60') it was the 950 version. i got the carb for $20 at the indy swap meet. it was missing the "mouse trap" choke & the 3barrel specific vacuum can (didn't need the choke anyway). i bought a rebuild kit for it & along the way i discovered that a 3310 750 vacuum can would bolt right on, so i used that along w/ the holley quick change spring cover. i also plugged the secondary metering plate & then drilled & tapped it for std. holley jets. & replaced the stock accel pump w/ 50cc version. i would not hesitate to re use this carb on my current project in my sig. pic., but it is gonna be blowthrough turbocharged & vac. secondary carbs don't work in that app., so i ended up selling it
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
