Re: Holley 3barrel Carb?
[Re: RacerGofKGB]
#88946
07/15/08 08:56 PM
07/15/08 08:56 PM
Posts: 5,118 Alone in the darkness
gamagoat6x6
super street
super street
The front half is identical to the 850 four barrel so jets and stuff are all interchangeable. They`re 3160 carbs so the secondary side has a metering plate with drilled jets like all the 60 series holleys and you can NOT swap it over to a metering block because the booster feeds are closer together than the four barrels.
`02 RAM2500 SPORT V10 4x4
`06 GMC sierra
NO cars
[Re: Mr.Yuck]
#88947
07/15/08 10:20 PM
07/15/08 10:20 PM
don't see why it wouldn't work just as good as a 4bbl. The rear butterflies have just been coverter to one single flap. Just make sure it will work on your intake. That rear door night get hung up on a standard 4 hole or dual plane intake.
obviously you never tried one. it has horrible street manners. sec.vac signal is weak, an all-round dog of a carb.
#88948
07/16/08 07:03 AM
07/16/08 07:03 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
nope never have, but then again I stay away from vacuum carbs anyway.
[Re: Mr.Yuck]
#88949
07/16/08 07:05 AM
07/16/08 07:05 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Weren't these a "loop hole" carb for Pontiacs in NASCAR?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: 76Beeper]
#88953
07/16/08 01:24 PM
07/16/08 01:24 PM
Posts: 1,385 Az
69hemibeep
Az
Full throttle is where it usually is,used it for years with no issues. I better keep the kill switch handy!
1969 Hemi Roadrunner 2nd owner
[Re: 76Beeper]
#88954
07/16/08 02:27 PM
07/16/08 02:27 PM
Posts: 1,476 Oh
RacerGofKGB
Got The Big One
Got The Big One
Oh
There's a write-up in the Holley manual against using those gears on carbs. Thier reasoning is that they will bind up over time and that could be when your at full throttle
Just a thought... Those gears look to be 1:1, so im sure a simple linkage could be made to do the same thing in place of the gears.
[Re: RacerGofKGB]
#88955
07/16/08 07:34 PM
07/16/08 07:34 PM
just a thought... those carbs are not worth doing period.
#88956
07/17/08 12:29 AM
07/17/08 12:29 AM
Posts: 1,611 Pataskala, Ohio
GTX70sixpack
Pataskala, Ohio
I had one, just looked at my Holley stash, must have sold it. Did find a really great small block bracket carb I forgot I had though, a 780 vacuum secondary double pumper. I think they only made these for a little over a year sometime in the mid 70s.
65 Belvedere II Station Wagon 69 Coronet R/T convertible 70 GTX 70'cuda 99 Dodge Diesel dually 4X4
[Re: kbeeper69]
#88959
07/17/08 10:13 AM
07/17/08 10:13 AM
Posts: 1,448 right between milan dragway & ...
Flite_727
i had one on my street/strip, mild 440 powered 4000 lb.'82 D-150, it ran flawless high 11's on pump gas through the mufflers on ET streets.(best of 11:69 @ 112 with a 1.59 60') it was the 950 version. i got the carb for $20 at the indy swap meet. it was missing the "mouse trap" choke & the 3barrel specific vacuum can (didn't need the choke anyway). i bought a rebuild kit for it & along the way i discovered that a 3310 750 vacuum can would bolt right on, so i used that along w/ the holley quick change spring cover. i also plugged the secondary metering plate & then drilled & tapped it for std. holley jets. & replaced the stock accel pump w/ 50cc version. i would not hesitate to re use this carb on my current project in my sig. pic., but it is gonna be blowthrough turbocharged & vac. secondary carbs don't work in that app., so i ended up selling it
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
