Steering gear box question #88936
07/15/08 11:23 AM
07/15/08 11:23 AM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
I had just had my steering gear box rebuilt and I need to put it back in. My question is the pitman arm is off the gearbox so how do I find the center of the turn so I can put it back on the gearbox?
Re: Steering gear box question [Re: Shatar4] #88937
07/15/08 11:41 AM
07/15/08 11:41 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Turn it all the way one way to lock and then count the turns the other way until it locks and divide by two. Then turn it back that many turns and you're centered.
Re: Steering gear box question [Re: stumpy] #88938
07/15/08 12:17 PM
07/15/08 12:17 PM
check & see if it has a master spline
Re: Steering gear box question [Re: stumpy] #88939
07/15/08 07:33 PM
07/15/08 07:33 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Leave the roll p[in out until you are 100% sure it's centered correctly.
