Re: 01 Dodge cranks FOREVER!
[Re: Haibach Boys]
#888768
12/26/10 06:55 PM
12/26/10 06:55 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
The injectors might still be the problem. You can check them for leakage by popping them out of the intake and leaving them in the rail and actuating the fuel pump. Look for fuel to leak out of the tips. Just make sure the safety clips are on them so they dont blow out of the rail.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#888770
12/26/10 07:19 PM
12/26/10 07:19 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
My 96 Indy Ram was doing the same thing. Try turning the key on and let the fuel pump prime first,if it starts right up,then the pump is weak. I parked mine after work one day a few months back and it wouldn't start. So I poured some fuel in the throttle body,and the the truck started right up. The fuel pump failed. I put a new pump in,and now the truck starts right up in about a half of crank.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: chargervert]
#888772
12/26/10 08:00 PM
12/26/10 08:00 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
Thats not really a very good test in this case. A bad check valve in the fuel pump, leaky regulator, or leaky injectors would give all the same results doing that.
