mallory double life duel point YC-365-HP? #888622
12/26/10 03:44 PM
12/26/10 03:44 PM
scratchnfotraction Offline OP
any one know if they make a 1-piece cap with male or female cap terms?
would like to repalce it to run better fatter wires
can only run a 7mm wire from the looks of it and I dont like the way the wire goes in the cap on the pointed studs
I posted this on the Q&A board,but thought some one over here will know for sure
TIA
Re: mallory double life duel point YC-365-HP? [Re: scratchnfotraction] #888623
12/26/10 04:01 PM
12/26/10 04:01 PM
Milledgeville, (central) Georg...
Bighead440 Offline
Bighead440  Offline
TIA
NAPA has them all day long, female type. Looks like a Prestolite MoPar cap but fits the DoubleLife Mallory. I think I have the part number... Yep- Echlin#MA5. They can order it!
Re: mallory double life duel point YC-365-HP? [Re: Bighead440] #888624
12/26/10 04:08 PM
12/26/10 04:08 PM
thank you very much
thats just what I need and a part# too
will it use the mallory rotor button thats with the 2-piece cap?
Re: mallory double life duel point YC-365-HP? [Re: scratchnfotraction] #888625
12/26/10 04:25 PM
12/26/10 04:25 PM
Bighead440 Offline
Bighead440  Offline
thank you very much
Lemme see, I have a YC365 here in the shop...
Works perfect with the button on mine!!! Our nostalgia rails (one MoPar "B" and one Buick 455) use the DoubleLife's converted with PerTronix Ignitors and we use the old type cap for the nostalgia look. I got the regular cap I told you about to go in an '80s truck application!
Re: mallory double life duel point YC-365-HP? [Re: Bighead440] #888626
12/26/10 04:56 PM
12/26/10 04:56 PM
kool!! thank for your help again
yep i swaped a 440 in my 88 truck,and then got the duel point dist for it so it looks old skool
but I want to use a 1-piece cap
I may go with a pertronix conversion also
Re: mallory double life duel point YC-365-HP? [Re: scratchnfotraction] #888627
12/26/10 05:24 PM
12/26/10 05:24 PM
Bighead440 Offline
Bighead440  Offline
The Ignitor conversion works great! We turn 7200+ with ours in the MoPar powered FED. Had it in a 383 (+.060"-395") and now the 471" stroker, ran 5.50 with the 395 and now runs 4.90s with the 471. No problems, we use a HyFire Mallory box and Accel CDI coil. You can use it with no box to fire a regular coil! Awesome setup, glad I could help... RB
Re: mallory double life duel point YC-365-HP? [Re: Bighead440] #888628
12/26/10 06:56 PM
12/26/10 06:56 PM
7200+
I will be lucky to spin it to 5000
more of a poser race truck for car shows
good to know it will go high enuff to float my valves though
yes,that was a huge help for me,thank you
