727 tail shaft housing.
#888608
12/26/10 03:13 PM
12/26/10 03:13 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
How hard is it to change out? Have a 727 out of a 69 D200 but does not have the ears for the floor shifter bracket thats in my 72B. Many thanks
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: 727 tail shaft housing.
[Re: moparmarks]
#888609
12/26/10 03:28 PM
12/26/10 03:28 PM
RapidRobert
If the trans is out turn it upside down & take out the bolts of course then w a large phillips screwdriver take out the 2 screws and the plate then spread the snap ring w your largest "expanding" snap ring pliers (& hold it spread) as you pull the housing rearward.
[Re: dvw]
#888612
12/26/10 04:50 PM
12/26/10 04:50 PM
moparmarks
Thanks Tranny is out of car so I can set it nose down. Speedo gear is out. Was fixing to change seals and put in my car when I noiced that it didn't have the ears.
[Re: moparmarks]
#888614
12/26/10 06:47 PM
12/26/10 06:47 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Place the shift lever in Park (full back) and turn the output shaft until you hear it click into Park; makes the housing easier to remove/install.
