Re: 4 bolt main cap conversion on a 440
[Re: A47]
#888495
12/26/10 11:55 AM
12/26/10 11:55 AM
Posts: 1,328 St. Louis, MO
mopardamo
St. Louis, MO
Hello & Merry Christmas, I would put AL caps on and be done with it unless you are going to make under 500 hp. Then stick with the stock caps. Cannot do any better unless the block is upgraded. Damon
[Re: A47]
#888496
12/26/10 03:01 PM
12/26/10 03:01 PM
Posts: 43,195 Bend,OR USA
Cab_Burge
I agree with AHY on this, use either a set of ductile iron or aluminum caps and a good set of studs for builds above 600 HP I like and use the Mopar brand of ductile iron caps, I'm not sure if you can still get them or not I am a member of the 500, 600, 700, 800 and 900+ HP HP pump gas club All using Mopar Ductile iron caps Stay away from drilling or machining holes through the side of the block to use side bolts Look at that very closely and then about it If you want a block with four bolt mains buy a new one
[Re: thehemikid]
#888499
12/27/10 08:52 AM
12/27/10 08:52 AM
Posts: 384 under the hood
A47
under the hood
thanks guys for the info pictures replies & stuff , its been greatly appreciated !! yeah could go aftermarket 4 bolt mains block , but , thinking would be easier on bank account , it i could make use of this 71 block , i know power & cheap don't really go in the same sentance ! , these aluminum main caps ! something is bothering me !! don't laugh Guys , i know my way around engines & rebuilt a good few over the years , but will never know half as much as you guys on here , wont the aluminum main caps expand different to the cast iron block ! & change bearing clearences !! yeah said you would laugh ,
[Re: roadrunninMark]
#888500
12/27/10 09:23 AM
12/27/10 09:23 AM
Posts: 6,295 U.S.
moparniac
U.S.
how much are the caps and how much would the machining be for the whole process!
Mopar Performance
[Re: A47]
#888502
12/27/10 11:08 AM
12/27/10 11:08 AM
A47
under the hood
also what about aluminum caps in a motor that will spend lot of time on the street ,
[Re: A47]
#888503
12/27/10 05:02 PM
12/27/10 05:02 PM
Posts: 1,805 ky hills
thehemikid
ky hills
...The street was what I built that AL cap'd block for, but health got in the way & I didn't get to find out. Yeah, it'd be nice to hear someone say, "been there done that, no probemo", & I bet there is. Hopefully someone chimes in.
[Re: mopardamo]
#888505
12/27/10 09:40 PM
12/27/10 09:40 PM
Posts: 121 mid-mich
turboplymouth
mid-mich
I have 3 seasons on my AL caps. Probably 2500 driven miles and 25 1/4 mile passes, plus quite a few "street passes". You can take a guess on the hp based on the #'s in sig.
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj.
9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
[Re: turboplymouth]
#888506
12/27/10 10:05 PM
12/27/10 10:05 PM
Posts: 5,160 Texas
dannysbee
Texas
They do aluminum blocks with steel caps all the time and there does not seem to be any problems there with the different expansion of materials.
Getting old just means you were smarter than some and luckier than others.
[Re: A47]
#888508
12/28/10 09:22 AM
12/28/10 09:22 AM
Posts: 10,006 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My experience has been that total rotating assembly weight is as important as how you choose to strengthen the block. The next motor I get is going to have aluminum rods, the lightest piston I can come up with and a low deck race block from KB. My last choice would be what i have now, a four bolt Megablock with a 2432 bob weight. I don't like the idea of a conversion four bolt kit simply based on the fact that I have hurt a better four bolt combo, the factory four bolt race block. The best choice for a stock type 440 block IMHO would get a set of aluminum caps, and I would spend as much or more money on light parts to keep the bob weight as low as possible.
