which 340 block #887824
12/25/10 12:11 AM
12/25/10 12:11 AM
az
stage3 Offline OP
stage3  Offline OP
az
I will be doing a resto on a 72 Demon 340 H code car and have a question as to engine block. Car will not be a total OE resto but I'd like to get as close to possible as money takes me. I have two non original 340 blocks to use for this build...1/73 warranty block no VIN# and a 5/72 block with incorrect VIN#'s. Which do I use and/or do I mill off VIN's. Thanks for your replies! Rick
Re: which 340 block [Re: stage3] #887825
12/25/10 12:19 AM
12/25/10 12:19 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Milling off a VIN is illegal & it also wipes out some history.
Neither one will ever match your car, so use the one in the best condition.
Re: which 340 block [Re: stage3] #887826
12/25/10 12:26 AM
12/25/10 12:26 AM
az
stage3 Offline OP
stage3  Offline OP
az
Sorry to mention but car was built in 5/72.
Re: which 340 block [Re: stage3] #887827
12/25/10 12:35 AM
12/25/10 12:35 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Use the warranty block and don't add anything to it.
Re: which 340 block [Re: ScottSmith_Harms] #887828
12/25/10 01:45 AM
12/25/10 01:45 AM
Alabama
BigMoneyLewis Offline
Alabama
Me personally, I'd rather have the '72 block with incorrect sequential number , but close date code ,instead of a wrong year block .
Greg
gregward@mchsi.com phone 256-852-0955
Re: which 340 block [Re: BigMoneyLewis] #887829
12/25/10 01:52 AM
12/25/10 01:52 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
My reasoning for the warranty block with a later date casting is that (if) it had actually had a warranty replacment back in the day, most often the block would be cast in a later production model year, If you were getting judged at OE either one would get you the same score, with the ICCA OE judging no extra points are given for numbers matching, it was decided to let that slide to leave less incentive for a builder to restamp a block in an effort to gain points. We would not want to promote such an edeavor even indirectly.
