Degree wheel holder #887750
12/24/10 10:49 PM
12/24/10 10:49 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
Who makes a crankshaft socket that will hold a degree wheel? found chevy but no mopar
Re: Degree wheel holder [Re: rowin4] #887751
12/24/10 10:52 PM
12/24/10 10:52 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
comp makes 1 but it will move on the snout so only turn in 1 direction or do what I did and use the flexplate bolts to turn the engine so I could turn it either way without moving the holder for the degree wheel.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Degree wheel holder [Re: rowin4] #887752
12/24/10 10:53 PM
12/24/10 10:53 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: Degree wheel holder [Re: WILD BILL] #887753
12/24/10 11:06 PM
12/24/10 11:06 PM
Kissimmee Fl.
Kissimmee Fl.
that's the 1
Re: Degree wheel holder [Re: WILD BILL] #887754
12/24/10 11:20 PM
12/24/10 11:20 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
http://www.summitracing.com/parts/CCA-4799/
I just bought one the other day,big improvement over pinching it in between washers and fighting with getting it aligned!
Keith
Re: Degree wheel holder [Re: Dunnuck Racing] #887755
12/25/10 12:09 AM
12/25/10 12:09 AM
rowin4 Offline OP
rowin4  Offline OP
Thanks guy's
Re: Degree wheel holder [Re: Dunnuck Racing] #887756
12/25/10 12:32 AM
12/25/10 12:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Keith
Why worry about moving the wheel... I just move the
pointer(just bend it back and forth)... yeah it needs
to be within 10* or so of 0
Re: Degree wheel holder [Re: rowin4] #887757
12/25/10 12:06 PM
12/25/10 12:06 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I drilled and tapped a #10x32 fine thread hole about half way down the keyway slot so the edge of a hard allen head screw just extended into the slot so when it's tightened down after you slide the socket on the crank there is no socket wiggle at all. Works great. No degree wheel movement at all.
Re: Degree wheel holder [Re: MR_P_BODY] #887758
12/25/10 12:38 PM
12/25/10 12:38 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
Keith
Re: Degree wheel holder [Re: blownzoom440] #887759
12/25/10 01:19 PM
12/25/10 01:19 PM
Az
Crizila Offline
Crizila  Offline
Az
There is a better way - IMO. I took my wheel and cut the center out of it. I then made an adapter out of 1/4" thick aluminum with a step in it the thickness of the wheel ( around 1/16" ). Drilled and taped the edges ( 6-32 ) in 3 spots for set screws. Also made 3 adaptors ( above wheel )to take 3 different sizes of dampener bolts to handle any engine I may be working on. With the proper adaptor, I use the dampener bolt ( may have to washer up some ) and bolt the center section up solid to the crank snout. I can then rotate my wheel as needed and lock it down with the 3 set screws. Done! I can rotate the engine in ether direction with no slop. I love dis country!
Fastest 300
Re: Degree wheel holder [Re: Crizila] #887760
12/26/10 03:58 AM
12/26/10 03:58 AM
rowin4 Offline OP
rowin4  Offline OP
That's a great way to do it. I don't have a way to machine the wheel or the center, I doubt a hole saw would do the job. Great idea, thanks for sharing .
Re: Degree wheel holder [Re: rowin4] #887761
12/26/10 12:26 PM
12/26/10 12:26 PM
Az
Crizila Offline
Crizila  Offline
Az
Thanks. Another bennie is if you need to make cam timing changes, just remove the three set screws & outer ring, and you have full access to the cam gear.
Fastest 300
