big block 590 purple shaft cam spec?
#887528
12/24/10 08:36 PM
12/24/10 08:36 PM
Posts: 501 ONTARIO,CANADA
604 Hemi GTX
ONTARIO,CANADA
Does anyone have a cam card on a 590 purple shaft. I just bought one from my local dealership and it didn't come with a cam card. I need the spec to dial the cam in. Thanks for any and all info Kevin
Re: big block 590 purple shaft cam spec?
[Re: Sport440]
#887535
12/24/10 11:16 PM
12/24/10 11:16 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
supposed to be 265/265 @ .050 the rest is above.
But its not! Its duration is actually 271/272 @ .050 thereabouts,
Reguardless, 265 or 272 install it at between 98* to 102 ICL for best performance in most apps. mike
we had my friends in at 104 and I talked him into 100 and it was snappier at 100
[Re: Dunnuck Racing]
#887537
12/25/10 01:10 AM
12/25/10 01:10 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Some of those spec.s are quite a bit different than what I remember WOW ' I too have run and am running the .590. Lots of people say "theres better cams" I`ve just never found one. Is that really a 114c/l on the 484hyd? I`m putting a blower on my 383 and was looking for a cam with 112--114 lobe centers ,but it already has a 484 which IS a 114????? I thought the 484 was 110 c/l?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: mike s]
#887540
12/25/10 05:06 AM
12/25/10 05:06 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
there are two versions of the 484/509 cam for BB...108 and 114 center line
SB only shows the 484 cam with both Center lines available..
but my catalog is a couple years old
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 572charger]
#887542
12/25/10 01:08 PM
12/25/10 01:08 PM
Posts: 553 Kentucky
clovis
Kentucky
Here is the card that I got from the Tech line guys. As everyone has said and the new paperwork details the duration at .050 is actually 271. This just gives you the opening and closing points.
312° Mechanical: P4120663 Duration Intake Nominal 312° Duration Exhaust Nominal 312° Duration Intake @ .050” 265° Duration Exhaust @ .050” 265° Intake Lobe Centerline 104° ATDC Exhaust Lobe Centerline 108° BTDC Lobe Separation Angle 106° Overlap 100° Intake Opens 52° BTDC Exhaust Opens 84° BBDC Intake Closes 80° ABDC Exhaust Closes 48° ATDC Intake Lift .590” Exhaust Lift .590” Note: as installed on 104° centerline per Chrysler
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: clovis]
#887543
12/25/10 01:26 PM
12/25/10 01:26 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
I've posted this before but, this is what I've found on the MP/DC Purple SOLID cams: Their advertised durations use timing events @ .015" I typically find, duration @ .020" is 8º less. i.e. 312/590 cam is 304º @ .020" Duration @ .050" is 32º less than duration @ .020" So the 312/590 cam looks like this: 304º @ .020" 272º @ .050" I hope that helps.
[Re: 604 Hemi GTX]
#887544
12/25/10 04:01 PM
12/25/10 04:01 PM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
What do you guys recommend for valve springs?
Comp 928 or K-Motion 850. My choices.
[Re: 604 Hemi GTX]
#887546
12/25/10 05:59 PM
12/25/10 05:59 PM
Posts: 16,923 NC
440Jim
NC
In addition to the actual duration at 0.050", this is what Dwayne Porter measured on one a few years ago. MP .590 cam, actual measurements- DUR. @ .020=303.5 .050=270.5 .100=235.0 .150=205.0 .200=177.0 .250=148.5 .300=117.0 .350=76.0 lobe lift@TDC @105 ICL=.140 LSA 106
[Re: shoebox]
#887547
12/25/10 06:01 PM
12/25/10 06:01 PM
Posts: 16,923 NC
440Jim
NC
440 2295s 070 in the hole 260cfm at 600 452s small valves
Gus, I have a feeling the 0.590" cam might like more compression ratio than you have. What is the combustion chamber size on your set of 452 heads? They vary a lot.
[Re: Sport440]
#887550
12/25/10 08:13 PM
12/25/10 08:13 PM
604 Hemi GTX
ONTARIO,CANADA
What would you recommend for rockers and what type of retainer steel or ti.Just curious what you guys recommend. Thanks Kevin
[Re: AAR-B4]
#887551
12/25/10 08:49 PM
12/25/10 08:49 PM
Posts: 1,090 Saskatchewan, Canada
barracudabob
Would these work with 1.6 rockers as well?
[Re: SILVER67]
#887553
12/25/10 09:45 PM
12/25/10 09:45 PM
604 Hemi GTX
ONTARIO,CANADA
Hey Guys,
Has anyone gone from say a .509 hyd. to the .590? How much of a difference would there be given say a 10.5:1 440 fairly ported big valve 906 heads. 3800 pound b-body.
that is kind of the same situation i'm in,but mine is 542ci,915 heads ported,comp?509 hyd and going to a 590 solid,single plane intake and dominator. Oh ya and the best mine has run was 10.92@123 and trying to get to maybe 10.50
[Re: barracudabob]
#887554
12/25/10 09:49 PM
12/25/10 09:49 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I ran the .590 with 1.6's and Comp 928 springs for several years without any issues. Keith
[Re: 6bblFLASH]
#887556
12/25/10 10:15 PM
12/25/10 10:15 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I love the 590! I installed it at 104 in a 3050# DartSport with an 11.2:1 451. I used Harland 1.6 rockers on the Eddy heads, Isky 8005a springs with steel retainers. Ran 9.90's at 136 MPH all motor. New owner has gone 9.77 in the car. I never tried advancing the cam more, I wouldn't want to lose MPH and it had PLENTY of torque at 104.
