what oil pump do you guys like? #887420
12/24/10 07:08 PM
12/24/10 07:08 PM
glendora, ca.
Deepockets Offline OP
glendora, ca.
i have the indy external pickup with the screw on filter and want to replace the pump portion, any prefferances. this is a new build so i thought i'd just get a new one. 7000 to 7200 rpm max. 528 ci. just wondering whats best or who's to stay away from.
Re: what oil pump do you guys like? [Re: Deepockets] #887421
12/24/10 08:15 PM
12/24/10 08:15 PM
1 word TITAN
Re: what oil pump do you guys like? #887422
12/24/10 08:55 PM
12/24/10 08:55 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I went with milodon , covering the whole oil system
Re: what oil pump do you guys like? [Re: Mopar-Al] #887423
12/24/10 09:48 PM
12/24/10 09:48 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
P and P , System one and Titan are all good pumps . I just bought a Daileys engineering dry sump pump its pretty trick
The Milodon dual pick up oil system should be avoided like the plague . Spend a bit more money and buy a pump that wasn't designed 25 years ago and doesn't work half the time .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: what oil pump do you guys like? [Re: go green] #887424
12/24/10 09:52 PM
12/24/10 09:52 PM
Get-X Offline
Get-X  Offline
Auto Verdi 5 stage for the Hemi, Titan if it were a wet sump.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: what oil pump do you guys like? [Re: Deepockets] #887425
12/24/10 10:23 PM
12/24/10 10:23 PM
If your talking about a bracket motor or a N/A motor under 700 HP I would and do use a Mellings or Speed Pro high volume pump main body with your top Clean it and isnpect it before use of course
Re: what oil pump do you guys like? [Re: Cab_Burge] #887426
12/24/10 11:52 PM
12/24/10 11:52 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I've neen using a Milidon with no issues besides green gasket failure but bought the MMotors deal. I think I'm going to upgrade on the next rebuild though, maybe a Titan or System One.
Re: what oil pump do you guys like? [Re: camastomcat] #887427
12/25/10 09:42 AM
12/25/10 09:42 AM
pa
572charger Offline
572charger  Offline
pa
ray barton since 2003 ! big volume !
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: what oil pump do you guys like? [Re: 572charger] #887428
12/25/10 09:51 AM
12/25/10 09:51 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I am running the melling as of right now... someday I may try something different... who knows...
Mopar Performance
Re: what oil pump do you guys like? #887429
12/25/10 09:57 AM
12/25/10 09:57 AM
Lehigh Acres, Florida
rickstershemi Offline
1 word TITAN
Ditto
Rickster
Re: what oil pump do you guys like? [Re: moparniac] #887430
12/25/10 09:58 AM
12/25/10 09:58 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I just use a Melling standard volume oil pump on my 500" low deck that BigCube gave me. Pumps plenty of oil.
