Holley 600 cfm Carb on 318 Marine Engine #887349
12/24/10 06:09 PM
12/24/10 06:09 PM
Boston, MA
russg Offline OP
super gas
russg  Offline OP
super gas
Boston, MA
Would you recommend a jet swap to switch this carb from a 360 to a 318? I'm presuming it has to go a little leaner to avoid bogging and for better fuel economy.
Re: Holley 600 cfm Carb on 318 Marine Engine [Re: russg] #887350
12/24/10 06:36 PM
12/24/10 06:36 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Try it with original jets. Usually jetting has to do with altitude and cam specs. You can take a carb off a slant and put it on a 440 and itll run. 360 draws more air hence more fuel through the same jetting as a 318 so it may be correct as is. Many "universal" performance carbs work very well off the shelf on a wide range of motors. from 302s to 460s . I would go with a Carter 500 if you can find one or a Holley 450. Boats like torque and smallish carbs are great for that.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
