Where to find thin .030 or less head gaskets for 4.070 #887022
12/24/10 01:47 AM
12/24/10 01:47 AM
So Cal
autoxcuda Offline OP
So Cal
Looking for something under .030 head gaskets for my 416 4.070 bore build that will only be 10.2 to 1 or so compression.
Most sites list the P4120094 .028 compressed gaskets at 4.06 bore, which will not work for me. But some list that as 4.125 bore which I think is incorrect. ??
What about these Detroit gaskets I see on E-bay. They seem reasonable except for the ridiculous $20 shipping charge...
http://cgi.ebay.com/ebaymotors/ws/eBayIS...id=380234632604
Is there another source for these Detroit 4.125 bore gaskets? This is the only place I've seen these gaskets. Could this seller misrepresenting a set of P4120094 gaskets??
Re: Where to find thin .030 or less head gaskets for 4.070 [Re: autoxcuda] #887023
12/24/10 04:55 AM
12/24/10 04:55 AM
SoCal
Brian Hafliger Offline
SoCal
Cometic has them from .016 and up I believe.
Brian Hafliger
Re: Where to find thin .030 or less head gaskets for 4.070 [Re: Brian Hafliger] #887024
12/24/10 12:40 PM
12/24/10 12:40 PM
So Cal
So Cal
Is the MP 4120094 actually a 4.125 bore instead of the 4.060 bore in the MP catalog?
70aarcuda measured a set he had at near 4.125. But I don't know how old they were.
Wonder if the current MP 4120094 is actually 4.125 and mis-labeled in the MP catalog?
The .028 compressed would be fine for me. And they are like $35-$40/pair.
Re: Where to find thin .030 or less head gaskets for 4.070 [Re: autoxcuda] #887025
12/24/10 03:00 PM
12/24/10 03:00 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
i bought a set of those head gaskets off the same guy on ebay for my 418 stroker.they measured 4.150 on the id and were .027 thick.worked good for me gave me little more compression,and better quench without shaving heads.mike
Re: Where to find thin .030 or less head gaskets for 4.070 [Re: hp340nos] #887026
12/24/10 03:03 PM
12/24/10 03:03 PM
So Cal
So Cal
i bought a set of those head gaskets off the same guy on ebay for my 418 stroker.they measured 4.123 on the id and were .027 thick.worked good for me gave me little more compression,and better quench without shaving heads.mike
Where they the MP 4120094 gaskets? Are they the same gaskets?
Can this be the only guy selling these? Something doesn't sound right.
Re: Where to find thin .030 or less head gaskets for 4.070 [Re: autoxcuda] #887027
12/24/10 05:16 PM
12/24/10 05:16 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I have those gaskets in stock and just went and pulled a set. Although they are still in the plastic, they measure 4.150, closer to 4.160 ish. Non compressed about .034, so I am sure they will compress to about .028-.030.
I cannot say for sure that they are Detroit gaskets, as I didnt even think they were still in business. I believe they are repackaged ROLS from Mexico. I will do some research to get the correct information on their origin.
RIP Monte Smith
Re: Where to find thin .030 or less head gaskets for 4.070 [Re: CompWedgeEngines] #887028
12/24/10 07:52 PM
12/24/10 07:52 PM
So Cal
So Cal
So, CompetitionWedge and others, the P4120094 has an incorrect 4.060 bore description in the MP catalog??
Most all MP parts houses have that 4.060 bore in thier discriptions too.
Can someone contact Zippy about this at MP?
Getting the correct info out there could open up these parts to more potential customers. Like all the street/strip 340 and 416 stroker guys.
Re: Where to find thin .030 or less head gaskets for 4.070 [Re: autoxcuda] #887029
12/24/10 08:24 PM
12/24/10 08:24 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
yes what todd said at competition wedge engines,actually my dimension were exactly what todd measured,my id dimesion in the above post was incorrect,the gasket were white in color too not red like the older thin mp ones.
Re: Where to find thin .030 or less head gaskets for 4.070 [Re: hp340nos] #887030
12/24/10 08:43 PM
12/24/10 08:43 PM
So Cal
So Cal
That "not red" deal is what is throwing me. Troy from Westoaks MP has never seen a white one. But he hasn't done MP in about 1-2 years.
So a MP 4120094 will fit my 4.070 bore and be about .028 compressed. yes/no?
Re: Where to find thin .030 or less head gaskets for 4.070 [Re: autoxcuda] #887031
12/24/10 09:21 PM
12/24/10 09:21 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
they used to be red...then they were not available for several years...now they are a whiteist color..
actually Mr Gasket had the same one..pn 1121 but no one carries them anymore..used to buy them at Summit also.
this where i usually order them now..
http://www.monicattichrysler.com/comersus/store/comersus_viewItem.asp?idProduct=247
and that price is for a set...
Tony
70 AARCuda Vitamin C
Re: Where to find thin .030 or less head gaskets for 4.070 [Re: autoxcuda] #887032
12/24/10 11:07 PM
12/24/10 11:07 PM
Syracuse,NY
Syracuse,NY
These will clearly fit your 4.070 bore without any concern other than the bore size being a bit larger than you need. Its only about .040 per side however. Just drops compression a bit with that bore size, but makes it back up with the thinner gasket.
The " old red" gaskets were in fact Detroit gasket, not been available for years other than left over stock.
Like I said, I am 99% sure these are a copy of the Corteco gaskets, which were also tied in with ROL gasket company and I believe made now in Mexico. They arent a bad gasket.
RIP Monte Smith
Re: Where to find thin .030 or less head gaskets for 4.070 [Re: CompWedgeEngines] #887033
12/25/10 02:43 AM
12/25/10 02:43 AM
Milledgeville, (central) Georg...
Bighead440 Offline
Bighead440  Offline
I bought some of the thin white MP style gaskets from Summit just last month. Mr Gasket still makes the thin ones, .026" compressed, IIRC. They are the sticky coated-graphite ones that used to be orange back a few years. Have run them on 318s-340s, .060"over with zero problems. Over 11.5:1 I would run a MLS (Cometic-type) or a TITAN ICS gasket I think...RB
