Is a 276/284 Voodoo cam 60404LK too big for 340?
#887005
12/24/10 01:30 AM
12/24/10 01:30 AM
Posts: 1,018 Hazlet, NJ
440Satellite
super gas
super gas
Hazlet, NJ
I'm slowly piecing together the parts for a 340 build and need some cam recomendations. I was originally thinking about going with a XE274 Comp solid cam but the valvetrain has already been modified to where it uses pushrods for a solid cam (length) with a hydraulic cam, so instead of figuring out what size pushrods I would need on a solid, I'm now thinking of just running a good sized hydraulic, and the Lunati 276/284 VOODOO CAM/LIFTERS 60404LK looked pretty good.
So far my combo will be a 340 bored .030 over with milled TRW 13:1 dome pistons yeilding a 10.5:1 compression with 62cc J heads (they were cc'ed). The heads are fully ported and polished(dont know flow though) with longer than stock 2.058 intake and 1.60 exhaust Manley valves, a W2 style rocker setup with adjustabe crane rockers and double springs with positive seals. I'm going to be using an Air Gap intake, 750 Demon carb, Crane Hi-6 ignition, and headers, all hooked up to a iron 4 speed and 8 3/4 with 3:91's in a 72 Duster thats mini tubbed and running 325/50-15 street slicks.
The Voodoo cam is a fast ramp design with 234/242 duration at .050 and .513/.533 lift with 1.5 rockers. I want something to take advantage of the heads as they look really nice but is that too big for a 340? Its a weekend car to tear up the streets with and a couple trips to the track for fun.
What do you think, sound good or any better sugestions. I'd like to get the car into the low-mid 12's if possible maybe even high 11's with a shot of nitrous.
Butch
1972 Duster
318 4 speed
1958 392 Hemi engine
waiting to be built!!!!!
Re: Is a 276/284 Voodoo cam 60404LK too big for 340?
[Re: DaytonaTurbo]
#887007
12/24/10 10:28 AM
12/24/10 10:28 AM
440Satellite
super gas
super gas
Hazlet, NJ
So you think a solid would be worth the trouble. Its a fun car if I put 500 miles on it a year I'd be surprised. Want something nasty sounding with the power to back it up. Also I'm running manual discs and manual steering. All the work was already done to the engine when I bought it, including the heads, I'm just droping in some milled pistons to get compression down, getting it ballanced, and reasembling with a few new parts.
Solid and hydraulics are pretty much the same price so if determining pushrod length isnt too hard then it wouldnt really mater either way. The Comp 274 solid only has around .500 lift would that hurt over the 513/533 Voodoo?
Butch
1972 Duster
318 4 speed
[Re: Posest]
#887011
12/25/10 01:34 PM
12/25/10 01:34 PM
440Satellite
super gas
super gas
Hazlet, NJ
How do you like that cam, I realise you have more cubic inches but also a step up in cam. Hows the sound and power? Would you buy another Voodoo?
Butch
1972 Duster
318 4 speed
