64 Sport fury gauges #886965
12/24/10 12:41 AM
12/24/10 12:41 AM
Northwest
Four40mopar Offline OP
Northwest
I am stumped, the gas and temp gauges do not work. I have verifed both senders and wiring all the way through the circuit board to the post on the gauges. Tested the gauges and I know that they work. Verified power all the way through the circuit board to the middle pin of the voltage regulator on the cluster. Lost power at the voltage regulator, so I replaced it and cleaned the sockets. Still no power to the gauges. Has anybody had problems with these regulators before?
Re: 64 Sport fury gauges [Re: Four40mopar] #886966
12/24/10 09:07 AM
12/24/10 09:07 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Take the sender wire off either the fuel or temp gauge.Ground it and turn the key on.It should peg.Just dont leave the key on very long.If it dosent the gauge might be bad.The sender wire to the tank should flash a test light with key on also.Rocky
Chrysler Firepower
Re: 64 Sport fury gauges [Re: Four40mopar] #886967
12/24/10 11:21 AM
12/24/10 11:21 AM
Andrewh Offline
Andrewh  Offline
yes, they burn out eventually. they still sell them new as I recall, or you can look around and some people build a solid state replacement.
