sheet metal needed for 68 cuda - pan under rear seat #886689
12/23/10 07:28 PM
12/23/10 07:28 PM
iowa
I
irishracing31 Offline OP
I
iowa
Hello,
I just had my 68 cuda blasted and it revealed more rust then expected. What's new. I am in need of a repro panel or a clean peice out of someone's parts car. The panel I need is the piece that is under the rear seat on the passenger side. This is the panel that the floor pan over laps about 8" and then curves up and is under where your buttock would sit if you where in the right side back seat. I have attached a picture of the area I am talking about. I would like to get repro panel but would also be interested in a chunk cut out of a car if it is clean. Any help would be greatly appreciated.
Re: sheet metal needed for 68 cuda - pan under rear seat [Re: irishracing31] #886690
12/23/10 10:41 PM
12/23/10 10:41 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
your attachment is probably too big to post. Try reducing it.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: sheet metal needed for 68 cuda - pan under rear seat [Re: GO_Fish] #886691
12/26/10 10:43 AM
12/26/10 10:43 AM
iowa
I
I
iowa
Thanks, I didn't have a clue what to do to get the pic to show.
Re: sheet metal needed for 68 cuda - pan under rear seat [Re: irishracing31] #886692
12/31/10 12:51 AM
12/31/10 12:51 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
where do you guys buy the '68 B'cuda rear floor pans? AMD? Do any include the hump up beneath the seat bottom?
Re: sheet metal needed for 68 cuda - pan under rear sea [Re: irishracing31] #886693
12/31/10 02:02 AM
12/31/10 02:02 AM
Canada
demon Offline
demon  Offline
Canada
The panel you need is not reproduced however it is the same on all 67-76 A bodies. 2 or 4 doors. All the same
