Page 1 of 3 1 2 3
got a 340 intake for my 318 RR...what next? #886571
12/23/10 03:36 PM
12/23/10 03:36 PM
Pittsburgh, PA
bigdaddywiz Offline OP
Pittsburgh, PA
I've been looking to do this for a while now and finally over the summer I came across an intake, 4bbl and air cleaner off a 340 (stamps showing its off a '72) for my 73 Road Runner with a 318 2bbl.
Now I know people are going to say why not just do an engine swap?...well, i don't have the cash to change out the transmission and rear end to handle much more power let along find an entire engine as well. I know this isn't going to make my car a fire breather or anything, I just want a little more pep, and something to do over the winter while its in the garage.
Can anyone offer any pointers for this project? I know the carb will need rebuilt, but didn't know if i had to re-jet or anything like that since this will no longer be on a 340 block. Also, what gasket kit will I need to get? This will be be my first engine project, but I wouldn't consider myself a total noob.
right now, the only thing done to the car is straight pipes with classic series flowmasters. stock headers, but i do have what looks to be aftermarket headers that my dad had lying around his garage. don't know if they will work, but I'm sure I'd probably want to add those on later if they do.
any pointers for this would really be appreciated!
Thank you.
73 Road Runner 09 Challenger R/T
Re: got a 340 intake for my 318 RR...what next? [Re: bigdaddywiz] #886572
12/23/10 03:51 PM
12/23/10 03:51 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Back in the 70's I helped a buddy add a 70 340 intake, a Holley 600 & some Hedman headers to his 318/3spd Duster.. That car spanked some stuff it had no business running with... Like a 396 Chevelle & a 68 Camaro with a hotrodded 350 & gears..
Re: got a 340 intake for my 318 RR...what next? [Re: 1_WILD_RT] #886573
12/23/10 05:04 PM
12/23/10 05:04 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Gaskets will be fine. Use the composite intake gasket - not the tin 318 type. The sealing surface may get some what marginal in places and you want a good seal.
Don't listen to all the nay sayers that will tell you that this won't work or that you should do this or that in stead. Hey it will work and work well. Just do it and have fun. Nobody can tell you where to jet - each will be different.
Re: got a 340 intake for my 318 RR...what next? [Re: bigdaddywiz] #886574
12/23/10 05:30 PM
12/23/10 05:30 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
pretty easy change over, as stated above good gasket set, how do you know the carb needs rebuilt? what kind of carb?
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: got a 340 intake for my 318 RR...what next? [Re: MoparforLife] #886575
12/23/10 05:33 PM
12/23/10 05:33 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I will assume you are replacing the tiny two barrel on the 318.
You will have to buy or fabricate the throttle bracket, since the original is in the wrong place., and if you are running an automatic, some tweeking of the kick down linkeage will be needed.
As far as the carb, it should be in the ballpark as far as jetting, the factory jetted them lean to begin with, for emmisions...
Just plan more fuel stops ! Not that the carb will burn more fuel, just your foot will be listening to the music more often !
Re: got a 340 intake for my 318 RR...what next? [Re: sthemi] #886576
12/23/10 05:42 PM
12/23/10 05:42 PM
Pittsburgh, PA
Pittsburgh, PA
yeah i'm replacing the 2bbl carb with the 4bbl that came with the intake, so its whatever came on a 340 in 1972. I'm pretty sure it needs rebuilt cause it was sitting in this guys garage for a long time and everything seems dry rotted, like its been sitting for 20 years or so.
about the bracket that i'll need for the throttle linkage and kick down...it looks like it was attached to the carb. i'm not looking at it at this very moment, but i think it was all there. will i still need to fabricate or will the 340's linkage and brackets work?
Re: got a 340 intake for my 318 RR...what next? [Re: bigdaddywiz] #886577
12/23/10 08:41 PM
12/23/10 08:41 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The 340 throttle brackets should work.
Re: got a 340 intake for my 318 RR...what next? [Re: sthemi] #886578
12/23/10 08:59 PM
12/23/10 08:59 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
This is an easy swap. I've done it a couple times. However, each time a new Holley 600 was used. I would always get a intake gasket set for a 340. I never used the end gaskets, just a bead of silicone. Each time, we were able to just bend the 318 throttle bracket over a little to get better alignment with the carb. (Not too noticeable.) We'd always have all the parts ready to go and we'd joke that we (a buddy of mine and I) could complete the swap on a running car before the engine even cooled down.
Re: got a 340 intake for my 318 RR...what next? [Re: pinkduster] #886579
12/23/10 09:32 PM
12/23/10 09:32 PM
scratchnfotraction Offline
it is very important to have the throttle pressure valve linkage to save the tranz from burning up
a 2-v linkage can be mod o fried to work with very little work
if it has a flat rod from bracket to the carb stud
you can bolt 2 of those together to make it longer from the bell crank to carb stud
if its round threded rod you can cut and weld a piece in to make it longer and still be adjustable
usally needs 1" to 1.5" added to the linkage to be long enuff
I also bend in a slight s curve to aline it up to the carn stud
it needs to move freely with out the carb lever and the spring pull it back with out open the throttle
stock 4-v linkage would be ideal,IIRC it would be the 3 rod style for A-body
it will be a boost in performance even with the 2-v wimpy cam in the 318
4-v and headers will wake it up some,cam swap later to gain some more performance
done this swap many times over the yrs
should be a thermo bog on that 340,I would have it rebuilt or go with another carb,they can be pricey and feniky to get right for a first timer
600cfm eddie carb works great on them,IMO
here is the 88 360 headed 318 4-v cop engine in my stepside
600 eddie carb
LD4B intake
lunati voodoo roller cam
headers
deul 2.5 pipes
a999 HS/LU tranz
8 3/4 with 3.23 gears
runs strong and knocks back 19 mpgs daily driveing
Re: got a 340 intake for my 318 RR...what next? [Re: scratchnfotraction] #886580
12/23/10 09:50 PM
12/23/10 09:50 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
If your kickdown rod is the round threaded kind, the 2bbl version will be too short to reach the carb as said above. Edelbrock sells a cheap threaded extension a couple inches long to correct this problem. Summit sells them, they come in two different diameters depending on which diameter threaded kickdown rod you have. You will be happy with the upgrade. The Thermoquad spread bore carb you probably have will have an agressive sucking sound when you crack the secondaries open! You may not have to re-jet the carb, just clean up and re-gasket if you are half lucky.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: got a 340 intake for my 318 RR...what next? [Re: 1_WILD_RT] #886581
12/23/10 10:01 PM
12/23/10 10:01 PM
very Southern Indiana
skullbucket Offline
skullbucket  Offline
Uh well..... uh..... yea....
Here here have some more eggnog, I'll know when you had enough when the 318 whipped on an L-88 vette also!!!!
Re: got a 340 intake for my 318 RR...what next? [Re: skullbucket] #886582
12/23/10 10:37 PM
12/23/10 10:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Believe what you want... I was there... To be honest I was completely shocked too...
Re: got a 340 intake for my 318 RR...what next? [Re: 1_WILD_RT] #886583
12/23/10 11:16 PM
12/23/10 11:16 PM
i have seen a few little teens that could also
Re: got a 340 intake for my 318 RR...what next? [Re: scratchnfotraction] #886584
12/24/10 03:18 AM
12/24/10 03:18 AM
Pittsburgh, PA
Pittsburgh, PA
will this be something i have to buy separately or can i make either the 318 or 340 linkage work?
thanks, and sorry if this is obvious...got lots to learn!
Re: got a 340 intake for my 318 RR...what next? [Re: skullbucket] #886585
12/24/10 03:24 AM
12/24/10 03:24 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Haven't even been a member for 2 weeks yet and already bashing people you don't know? Nice.....
Re: got a 340 intake for my 318 RR...what next? [Re: bigdaddywiz] #886586
12/24/10 03:26 AM
12/24/10 03:26 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you can swing an intake change, can you swing a little more for a cam change? The summit k6901 cam/lifter kit is only 110 bucks and I'm sure someone on here can suggest a set of valve springs. Add in a set of aftermarket headsers and you'll really wake that 318 up a lot more than just doing the intake.
Re: got a 340 intake for my 318 RR...what next? [Re: DaytonaTurbo] #886587
12/24/10 04:09 AM
12/24/10 04:09 AM
Central Ohio
rtidd440 Offline
super street
rtidd440  Offline
super street
Central Ohio
Did this years ago with a 69 Charger. Someone put a rumpy cam in it and left the two barrel on it before I got the car. Put on a stock spreadbore manifold with a TQ. Ran real good for a 2 ton car.
Rob 70 Swinger 340 4spd FC7 4 sale 69 Charger auto Q5 14 Challenger SRT8 Core 6spd black Deposit on Hellcat
Re: got a 340 intake for my 318 RR...what next? [Re: rtidd440] #886588
12/24/10 10:19 AM
12/24/10 10:19 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
Back in the 70's i had a 70 model duster with a 318. I replaced the intake with one from a 273, put an AFB carb on and installed a stock 69 model 340 cam with dual exhaust. This made for a fun little car. I to surprised several bigger name cars. And as far as beating up on chebys, remember its just another cheby.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: got a 340 intake for my 318 RR...what next? [Re: DaytonaTurbo] #886589
12/24/10 11:39 AM
12/24/10 11:39 AM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I have run this cam on two different 318's with stock springs with no problems up to 5500 rpm. My 76 Feather Duster with this cam, a 72 340 TQ and duel exhaust was a screamer! The 4-speed and 3.55 gears helped too!
Re: got a 340 intake for my 318 RR...what next? [Re: rattler] #886590
12/24/10 11:44 AM
12/24/10 11:44 AM
if you have the 4-v 340 linkage use it
it basicly the same from the intake bracket down to the tranz
the longer piece will be from the bracket to carb rod
you can mod the 2-v linkage to work with ease,just ask on here when you ready to do it
see if you can post pics of whats on the car now and what peices you have from the 340
I have a few pieces that might help you get it done..they are free so it should be cheap for you to get it right
sounds harder than it is,but its one of the most important pieces on the car for tranz longevity and working correctly on the shifts
if you go junyarding any of the mid 80s 4-v cars F-R bodys( 5th aves-gran furys) would have a set up to use also..as long as its a 3 piece...just get all of it
some of the mopars use a one piece rod also,but it goes by body style
when I did my truck to stock q-jet,I just got the intake carb linkage all the way to tranz
when I went to LD4B and eddie carb stock linkage worked
there are some aftermarket cable set ups that are good also(bouchillon/lokar)
lets see what you got
Page 1 of 3 1 2 3
