Anyone ever replace a C-Body floor pan? #886506
12/23/10 02:12 PM
12/23/10 02:12 PM
dart1962_440 Offline OP
65-68 - the whole front pan - it looks like it goes up and becomes part of the firewall and looks like the subframe mounting boxes are attached to it as well. Any thoughts or ideas on how to do this are appreciated.
Re: Anyone ever replace a C-Body floor pan? [Re: dart1962_440] #886507
12/23/10 07:36 PM
12/23/10 07:36 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Looks like a circular saw?
Sorry, couldn't resist...
But seriously...
I'm working on a 70, but if you post some pictures of what you're fixing I'm sure I can point you in the right direction.
Rick
Re: Anyone ever replace a C-Body floor pan? [Re: RestoRick] #886508
12/25/10 11:17 AM
12/25/10 11:17 AM
Rick,
Thanks for the reply. I also posted on the C-body Dry Dock with pictures:
http://www.cbodydrydock.com/forum_viewtopic.php?5.109608
First set of pics are my donor car floors, second set is the vehicle in need. Already received a a lot of great replies. I'm open to any ideas to swap the floors out and save the car.
Pat
Re: Anyone ever replace a C-Body floor pan? [Re: dart1962_440] #886509
12/26/10 03:59 PM
12/26/10 03:59 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
When I went to do some rocker panel repair on my 66 Fury, I was shocked to see it how they attached the floor pan to the rocker. I thought it only could be adhesive but I said nah - no way - they hadn't started dong that till much later, but shure enough, someone chimed in and said Yah, it's adhesive.
Re: Anyone ever replace a C-Body floor pan? [Re: dart1962_440] #886510
12/26/10 04:26 PM
12/26/10 04:26 PM
North East Texas
TexasPowerRam Offline
super gas
super gas
North East Texas
Pat,
Keep us posted your car sounds like a great project.
John 2008 Ford F250 XLT 4x4 Crew Cab 1990 Ford Crown Victoria LTD, Ex TXDPS
Re: Anyone ever replace a C-Body floor pan? [Re: dart1962_440] #886511
12/26/10 05:47 PM
12/26/10 05:47 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
There are a couple of ways to do the install.Proper way is to gut the whole car...dash,heater box etc etc.Other way is to trim the pan lower down so you don't have to pull dash etc.We have done several C's both ways.When you remove the donor pan leave the seat braces attached.....less welding.If you go this route make sure the underdash area is well protected..underdash fires are nasty.65 to 68 pans will interchange but the 65 pan is quite a bit different shape wise to 68.This pan went into a 67 Monaco Fastop.
"Long Live Mopars"
Re: Anyone ever replace a C-Body floor pan? [Re: Furyman] #886512
12/26/10 05:53 PM
12/26/10 05:53 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
Installed shot.There are 3 different length rear footwells...ply/dodge/chry.
"Long Live Mopars"
Re: Anyone ever replace a C-Body floor pan? [Re: Furyman] #886513
12/26/10 06:33 PM
12/26/10 06:33 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
This is a Monaco 500 convert we did.
"Long Live Mopars"
Re: Anyone ever replace a C-Body floor pan? [Re: Furyman] #886514
12/26/10 06:35 PM
12/26/10 06:35 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
Installed shot.
"Long Live Mopars"
Re: Anyone ever replace a C-Body floor pan? [Re: Furyman] #886515
12/26/10 07:47 PM
12/26/10 07:47 PM
Commando1 Offline
Commando1  Offline
That is one scary looking picture!
Re: Anyone ever replace a C-Body floor pan? [Re: Commando1] #886516
12/27/10 01:00 AM
12/27/10 01:00 AM
Appleton, Wisconsin
rtmike Offline
rtmike  Offline
Appleton, Wisconsin
Wow, looks like a department store would fit in there. I would be scared of getting it out of square, and never being able to recover.
Its not primer its perma gray.
