Cracks in fiberglass Hemi scoop? #88645
07/14/08 07:41 PM
07/14/08 07:41 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
I am working on a fiberglass scoop and there are small hair line cracks all through it. how can I get rid of these so you wont see them when it is finished. Someone told me gel coat. Does anyone sell this in a spray can. THANKS !
Re: Cracks in fiberglass Hemi scoop? [Re: 340Scamp] #88646
07/14/08 07:58 PM
07/14/08 07:58 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
That's happens when you hit about 120mph.
Re: Cracks in fiberglass Hemi scoop? [Re: Dragula] #88647
07/14/08 08:02 PM
07/14/08 08:02 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
You'll need to grind away at it until the cracks are gone and rebuild it back up again.
You might need to drill some holes in the back to let a portion of the air out the backside. I know a few guys with fast racecars that have had to do that to prevent the hoodscoop from being torn up over and over.
Re: Cracks in fiberglass Hemi scoop? [Re: Neil] #88648
07/14/08 08:18 PM
07/14/08 08:18 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
when i repair spider cracks in new corvettes i use this stuff, fibertec #633 http://www.evercoat.com/productDetail.aspx?pID=13 it has kevlar fibers in it that helps strengthen the repair area.
you should completely grind out the cracks in the glass then spread this stuff in the area you just ground out. then i use this stuff, metal glaxe #416 http://www.evercoat.com/productDetail.aspx?pID=1 on top of that. this is the only products that will not bulls eye on me when i repair corvettes.
perception is 90% of reality
Re: Cracks in fiberglass Hemi scoop? [Re: Mr T2U] #88649
07/15/08 09:13 AM
07/15/08 09:13 AM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
Thanks guys much appreciated
