'01 Concorde heater Control??? #886451
12/23/10 12:39 PM
12/23/10 12:39 PM
Newfoundland Canada
Mopar1 Offline OP
Mopar1  Offline OP
Newfoundland Canada
I'm getting some grief from the heater control unit ('01 Concorde). It will only blow through the vents, no floor or defrost. It has power at the controls, I can hear the beep everytime I try the controls. The car sat in the drive way for the last 6 months. Stuck blendor? Could it be a vaccuum problem? Side note: I just had the engine replaced. Going to have a go at it tonight, any thoughts on where to look 1st?
Re: '01 Concorde heater Control??? [Re: Mopar1] #886452
12/23/10 03:22 PM
12/23/10 03:22 PM
ogletownpa
3
383'D Offline
383'D  Offline
ogletownpa
You can run a self diagnostic on the unit. You set temp at a certain degree and hold some buttons in on the unit and it will cycle through all the settings and give codes. However when I get home to look in my book for exact method,I wont have access to a comp till tuesday,Call a dealer and ask or look in a hanes manual.If the lights are going off and on ,you need another control
