Page 4 of 6 1 2 3 4 5 6
Re: old school but it works well.! 292/509 lets talk. [Re: Dads426] #886340
12/27/10 10:14 AM
12/27/10 10:14 AM
Maryville tn
67coronetman Offline OP
Maryville tn
Hello so that was a very good looking old school ride i think you said you sold it.? wow i would have kept that car post a few more pics if you got them and more info i bet it got lots of looks even from the other guys that don't like us mopar guys.!
Old car are me......
Re: I know its old school but it works well.! 292/509 cam [Re: Mr.Yuck] #886341
12/27/10 12:15 PM
12/27/10 12:15 PM
Maryville tn
Maryville tn
Did u ever rerun the dart with a good trans and see what time you got.?!
Re: I know its old school but it works well.! 292/509 cam [Re: 2boltmain] #886342
12/27/10 05:00 PM
12/27/10 05:00 PM
Maryville tn
Maryville tn
I don't personaly hate comp cams co.! I have ran alot of combos in my cars over the years and have found for me.!!! That a hdy cam set up is way more street friendly for what i use it for.!!
Re: I know its old school but it works well.! 292/509 cam [Re: 383man] #886343
12/27/10 08:39 PM
12/27/10 08:39 PM
Maryville tn
Maryville tn
Are you still running the car in the picture.? And that set up or did you change it .??
Re: old school but it works well.! 292/509 lets talk. [Re: 67coronetman] #886344
12/27/10 09:51 PM
12/27/10 09:51 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Wow that's a very clean looking car did it have stock heads.? factory or aftermarket what type tires out back when you ran it was the 292/509 cam the old profile.?
Sorry for the late reply. It had template ported '72 452 heads on it. A couple of tricks for weight transfer; late K-member set the engine back 1-1/2", rear hole on the spring perch moved the rear foward an inch. Tires were M/T drag radials with SS springs. The cam was the new profile (2007). Board member on here has it. If I had a garage big enough, it would still be mine
Here's another pic.
Re: old school but it works well.! 292/509 lets talk. [Re: @#$%&*!] #886345
12/27/10 11:14 PM
12/27/10 11:14 PM
grande prairie , ab , canada
68notch Offline
68notch  Offline
68 barracuda
71 440
9.5 compression
4 speed
3.91 sure grip
509 purple
dual 4 tunnul ram with 625 carters
still getting it together , havent got a chance to get it to the strip , but sure love the way it pulls
theres nothing as permanent as a temporary fix 70 super bee 79 red express 67 fargo 8o aspen rt
Re: old school but it works well.! 292/509 lets talk. [Re: 68notch] #886346
12/27/10 11:46 PM
12/27/10 11:46 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
70 gran coupe Barracuda with full interior and stuff
440 non rebuild short
purple 509 hydraulic
milled heads .060
Holley SP StreetDominator 440 intake idle-5500
Holley 850cfm
4000 rpm stall
4.10 gears suregrip
26" x 10" sticky tire
13 flat at 102mph
Needed more compression, gear , and stall.
Re: old school 292/509 Cam what performance did u get.? [Re: 67coronetman] #886347
12/27/10 11:54 PM
12/27/10 11:54 PM
Jensen Beach, Florida
pressureangle Offline
I absolutely loved mine. I built it in 1984 by the Direct Connection book, but used Stage IV heads as well. 11:1 compression, 509 cam advanced 4 degrees, and a CH4B dual-plane intake with 850 DP Holley and 2" Hooker Super Comp headers. I never got to the track, but with 4.10 gears it would annihilate 275/60-15 BFG T/As through 3rd gear if the street wasn't perfectly clean. It's a 4-speed car and drove like a perfect kitten, even with a very light aluminum flywheel. Had 18" of vacuum at 900 RPM idle, too. <edit> um...maybe that was 14" lol.
Why do I torture myself so?
Re: old school 292/509 Cam what performance did u get.? [Re: pressureangle] #886348
12/28/10 12:12 AM
12/28/10 12:12 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
When it comes to boards like this everyone recommends to only do it once the right way and its so cheap to buy this part you should do it based on that fact. Its like buying crap in bulk that goes stale before you ever eat it.
The adjustable valve train does open a pandora's box of spending, as stated above. On a 3000 or less budgeted engine, buying something needing an adjustable valve train adds another 500 bucks on top, and thats assuming you bought more expensive pistons with the right valve reliefs to allow more lift. And then you aren't getting much more because your 906 heads dont flow above .500 lift as previously stated. So you buy the stealth heads or eddys because they're only about 400-700 more than a valve job and new valves. And hopefully your aftermarket heads check out good and dont need cleaning up. You just turned a cheap 2500-3000 rebuild into a 4000+ rebuild. Sometimes its just easier to stick with what works if high 11s and low 12s are enough for you.
And a buddy of mine used the Comp 509 when his last 509 broke in half. Car idles pretty smooth and he said its must more street friendly, but pulls even a little bit harder up top. I think the Comp version would probably be a good cam to run, at least you can take advantage of some of the newer technology with the advantages of the old 509.
Re: old school but it works well.! 292/509 lets talk. [Re: Dads426] #886349
12/28/10 12:21 AM
12/28/10 12:21 AM
Maryville tn
Maryville tn
That is a sweet looking ride i like the old mopars the look is very unique.! Thanks So much.!
Re: old school 292/509 Cam what performance did u get.? [Re: GTX MATT] #886350
12/28/10 12:23 AM
12/28/10 12:23 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
1969 RoadRunner
446
906 ported, big valves
1 3/4 headers and three inch exhaust
Eddy RPM and 800 Eddy
J converter and 3.23's
275/60-15 BFG Drag Radials
3800 pounds
12:40's @ 108
Michael
Re: old school 292/509 Cam what performance did u get.? [Re: SILVER67] #886351
12/28/10 12:30 AM
12/28/10 12:30 AM
Maryville tn
Maryville tn
Its ok its still a mopar and i am very found of old school cars!.
Re: old school but it works well.! 292/509 lets talk. [Re: 68notch] #886352
12/28/10 12:31 AM
12/28/10 12:31 AM
Maryville tn
Maryville tn
Can't wait to hear what it runs.! no matter what it will still be a lot of fun to drive.!
Re: old school 292/509 Cam what performance did u get.? [Re: GTX MATT] #886353
12/28/10 12:42 AM
12/28/10 12:42 AM
Maryville tn
Maryville tn
Well i can tell you this my current set up has no problem running & running hard.! its not i don't have enough i could get 800hp with a few minor thing done in no time ** but i have made a choice to use a more mild street set up and get more use for what i want as far as a weekend play toy.!
** I had a very close friend that had a 70 cuda with a 950 hp stroker motor and hated it after he did it because there are limits to what u can & can't do that goes with everything.!
Like i have said before i am not hear to debate, to say my way is right and everone else is wrong i just like hearing what other have done with there cars by useing the mopar 292/509 cam if other like a different one then i say use it and enjoy.!
Re: old school 292/509 Cam what performance did u get.? [Re: SILVER67] #886354
12/28/10 09:43 AM
12/28/10 09:43 AM
Maryville tn
Maryville tn
Hey the picture at the bottom of the page of the 67 dodge coronet was that yours or is it still your.? Nice looking car.!
Re: old school 292/509 Cam what performance did u get.? [Re: 67coronetman] #886355
12/28/10 01:57 PM
12/28/10 01:57 PM
knox tn
W
wedgehead426 Offline
W
knox tn
I to like the 292/509 cam in my combos i have had in my cars for yrs. I see others like it and some say make a change well i am always very stand off with making alot of changes to a good combo that has a track record like the 292/509 cam i don't care who makes cams someone always gets a bad on from time to time. I say use what makes you happy.
Re: old school 292/509 Cam what performance did u get.? [Re: wedgehead426] #886356
12/28/10 02:03 PM
12/28/10 02:03 PM
Maryville tn
Maryville tn
Thanks for the reply what type car and how did it run could you give more details.!
Re: old school 292/509 Cam what performance did u get.? [Re: 67coronetman] #886357
12/28/10 02:09 PM
12/28/10 02:09 PM
knox tn
W
W
knox tn
It was a 67 satellite with a 440 bored .030 over stock rods KB pistons, 906 heads bigger valves and port work 440 torker II intake port matched and hooker headers,4:10 gears and 3800 stall it went 11:68 at 115 mph with the 292/509 cam. great street car.
Re: old school 292/509 Cam what performance did u get.? [Re: wedgehead426] #886358
12/28/10 04:58 PM
12/28/10 04:58 PM
Maryville tn
Maryville tn
Here's a video of my car doing a little burn out.!
http://www.youtube.com/watch?v=iLMuETuCen4
Re: old school 292/509 Cam what performance did u get.? [Re: 67coronetman] #886359
12/28/10 08:52 PM
12/28/10 08:52 PM
knox tn
W
W
knox tn
Nice car it seem to run good sounds great what all has been done to it.!
