Re: 440 compression ratio ?
[Re: pettyblue440]
#885986
12/23/10 01:31 AM
12/23/10 01:31 AM
Posts: 43,176 Bend,OR USA
Cab_Burge
I have a 440 with 906 heads that cc @ 72.25 w/ l2266 pistons. What cr do I have? Thanks, Jon
I don't know what the 72.25W/I12266 pistons means If you have the specs. on the piston deck hieght, piston dome or dish volumes, cylinder head combustion chamber volume, bore and stroke and head gasket thickness and bore size go to KB web site and click on calcultors, go to compression calculator and plug your specs in and see what they say you have Same thing plugged into Wallace Racngs web site will probally get a little different calculation
[Re: pettyblue440]
#885987
12/23/10 01:35 AM
12/23/10 01:35 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Close to 10:1 if the heads really are 72cc, they must be milled to a closed chamber (.100 cut). Those pistons are down about .090 in the hole. stock 88cc heads and the same pistons is like 8.8:1 I used a 4.45 x .020 steel shim gasket volume BTW. If a felpro is used it could be .3+ compression less.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: pettyblue440]
#885989
12/23/10 09:26 AM
12/23/10 09:26 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
wow how did you get the heads down that far? If they have been cut you will have to cut your intake and be careful with your push rods.
[Re: dennismopar73]
#885992
12/23/10 12:39 PM
12/23/10 12:39 PM
Bob_Coomer
Rock Springs
I have seen a few sets of 906/452's milled so much they are a closed chamber head. Like I say it takes a .100 cut. I milled a set of 516's one time .080 LOL
[Re: pettyblue440]
#885994
12/24/10 01:12 AM
12/24/10 01:12 AM
Posts: 2,177 ill
dennismopar73
ill
mmm yes 'if ' that what they are 10-1 buy the way DO NOT GET THEM HOT
