Re: 69 Charger headlights flashing on and off [Re: eds dart] #885979
12/23/10 09:47 PM
12/23/10 09:47 PM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
Had a 69 R/T that did the same thing. there is a plug/disconnect under the battery tray that was corroded badly. Cleaned it up and no more problems. Hope yours is that simple.
Forgot about that connection...........mine sits right beside the battery against the inner fender.
Chrysler picked a great spot for it didn't they
Be sure to check it !
Good luck
Re: 69 Charger headlights flashing on and off [Re: idrivevintage] #885980
12/23/10 10:04 PM
12/23/10 10:04 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Lots of things can make them blink. Before sinking more money into switches, make sure you go over ALL the connections in the headlight circuit. The connector near the battery sounds like a potential problem. Another bad connection spot is at the bulk head connector where the wiring passes from the dash to the engine compartment. It is not uncommon to find that connection corroded green and burnt up. When a connection is nearing complete failure, it can blink the lights as the electricity struggles to bridge the increasingly burnt up wire and/or connection. Of course, the more this happens, the hotter the connection gets and the worse it burns. The same problem happens at the headlight switch. As said above, if the switch burns up, it can also damage the bakolite connector on the harness. If the connector is melted or damaged, replacing the switch itself and plugging the damaged connector back on a new switch will not solve the problem. Doing this could also cause the new switch to heat up and fail. BTDT!
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 69 Charger headlights flashing on and off [Re: GO_Fish] #885981
12/23/10 11:11 PM
12/23/10 11:11 PM
Glendale, AZ
69L78Nova Offline OP
Banned. Forever.
Banned. Forever.
Glendale, AZ
Hey thanks everybody for the great info. Gonna check it out tomorrow. Hopefully its something simple (it usually is)
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 69 Charger headlights flashing on and off [Re: 69L78Nova] #885982
12/24/10 12:34 AM
12/24/10 12:34 AM
indy
E
eds dart Offline
eds dart  Offline
E
indy
Yea, from a previous post it looks like it is next to the battery, still a very bad place to put a plug. Bought that car in 72, sold it in 74 and the quarters were already rusted through! Chicago winters.
Re: 69 Charger headlights flashing on and off [Re: eds dart] #885983
12/24/10 12:41 AM
12/24/10 12:41 AM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Chicago winters.
Yep Southsider here!
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: 69 Charger headlights flashing on and off [Re: 69L78Nova] #885984
12/24/10 01:18 AM
12/24/10 01:18 AM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I have checked this connection near the battery and found no problems. Headlights still flash.
