Re: 69 Charger headlights flashing on and off
[Re: eds dart]
#885979
12/23/10 09:47 PM
12/23/10 09:47 PM
Posts: 1,589 My Garage / Museum
idrivevintage
Chrysler Plant
Chrysler Plant
My Garage / Museum
Had a 69 R/T that did the same thing. there is a plug/disconnect under the battery tray that was corroded badly. Cleaned it up and no more problems. Hope yours is that simple.
Forgot about that connection...........mine sits right beside the battery against the inner fender.
Chrysler picked a great spot for it didn't they
Be sure to check it !
Good luck
[Re: idrivevintage]
#885980
12/23/10 10:04 PM
12/23/10 10:04 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Lots of things can make them blink. Before sinking more money into switches, make sure you go over ALL the connections in the headlight circuit. The connector near the battery sounds like a potential problem. Another bad connection spot is at the bulk head connector where the wiring passes from the dash to the engine compartment. It is not uncommon to find that connection corroded green and burnt up. When a connection is nearing complete failure, it can blink the lights as the electricity struggles to bridge the increasingly burnt up wire and/or connection. Of course, the more this happens, the hotter the connection gets and the worse it burns. The same problem happens at the headlight switch. As said above, if the switch burns up, it can also damage the bakolite connector on the harness. If the connector is melted or damaged, replacing the switch itself and plugging the damaged connector back on a new switch will not solve the problem. Doing this could also cause the new switch to heat up and fail. BTDT!
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#885981
12/23/10 11:11 PM
12/23/10 11:11 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Hey thanks everybody for the great info. Gonna check it out tomorrow. Hopefully its something simple (it usually is)
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
