Holley troubles #88574
07/14/08 04:28 PM
07/14/08 04:28 PM
Hunt Valley, Maryland
1fastrunner Offline OP
I was trying to adjust my front floats on my 750 dbl pumper and gas started spewing of of the adjustment screw and nut. Am I doing something wrong?
Re: Holley troubles [Re: 1fastrunner] #88575
07/14/08 04:45 PM
07/14/08 04:45 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Couple things here:
1) the HEX portion actually controls the fuel level. The slotted bolt on top is the lock. Make sure you loosen the lock first, and tighten it last, while holding the hex with a wrench.
2) The gaskets are very delicate (especially the one under the hex), they don't put up with much before they leak. There are vinyl replacements on ebay that work pretty good and are FAR tougher. You can just buy Holley replacements though.
Re: Holley troubles [Re: Pacnorthcuda] #88576
07/15/08 09:24 AM
07/15/08 09:24 AM
Western Colorado
3
340Scamp Offline
340Scamp  Offline
Western Colorado
Yes you are using a holley. Get an Eddy carb. its the best thing I ever did.
Re: Holley troubles [Re: 340Scamp] #88577
07/15/08 10:52 AM
07/15/08 10:52 AM
I appreciate your Eddy vote, but my holley is paid for. Actually I discovered some plug wires that might have not been on all the way. I fixed that and richened the carb a tad, and it now runs pretty good for a tired old motor. I also noticed my front bowl fuel level was a little low so that got adjusted as well. I lost the level sight bolt(long & stupid story, not really that long either), and went to purchase another as well as a new needle and seat. I discovered that Moroso makes a clear sight plug so that was a nice addition.
Wish me luck on my trek to the Syracuse Nationals and say hi if you go.
Re: Holley troubles [Re: 1fastrunner] #88578
07/15/08 03:00 PM
07/15/08 03:00 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
My Holley's were "paid for" as well, and I had to replace needles/seats once a year, adjust the floats, etc., and got so tired of it I sprung for a used Edelbrock, and only have to get in and start it now. When I want. Without fidling. Well worth it, I thought!!!!!
Re: Holley troubles [Re: 4BBodies] #88579
07/15/08 03:48 PM
07/15/08 03:48 PM
So,are you giving your old Holley's away?
Re: Holley troubles [Re: 1fastrunner] #88580
07/17/08 03:14 PM
07/17/08 03:14 PM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
No, I still have one that runs fine (I use premium with all sorts of additives).......I will keep it.......but I think in my area anyway, that the gasoline being sold really affects older carbs. I mean, I had to replace the needles/seats once a year, the rubber was cracking. I was going to try viton tips next, but it flooded, backfired, and sprayed the engine with gas REAL good and scared the crap out of me. I had dual 600's, they never ran well together, and I just got fed up, I am sure some of you have been there.
