{{{{ THREADED TUBING }}}} #885701
12/22/10 09:05 PM
12/22/10 09:05 PM
Lehigh Acres, Florida
rickstershemi Offline OP
Where are you guys getting it....????? Need (2) 12" lengths of 5/16 OD that I can tap to 1/4-24 I believe is fine thread right...???? It's for a progressive linkage setup the has (2) short lengths that ain't gonna work
Could get away with (1) 12" piece, but will make one non-progressive just in case I want to change it later
Rickster
Re: {{{{ THREADED TUBING }}}} [Re: rickstershemi] #885702
12/22/10 09:12 PM
12/22/10 09:12 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Rickster
1/4-28 is fine thread. You can use 5/16" OD tubing that has a 3/16" or smaller ID, drill out with a #3 or 7/32 bit, and tap your 1/4-28 thread.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: {{{{ THREADED TUBING }}}} [Re: rickstershemi] #885703
12/22/10 09:16 PM
12/22/10 09:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry cant help... I drill and tap that stuff in
my lathe... 1/4 X20 or 1/4 X 28... I assume you want alum
Re: {{{{ THREADED TUBING }}}} [Re: DusterDave] #885704
12/22/10 09:20 PM
12/22/10 09:20 PM
Rickster
Where can you get it locally Dave....?????? 1/4-28 that's it...have the drills & taps was just too lazy to go look....lol
Yes aluminum
Rickster
Re: {{{{ THREADED TUBING }}}} [Re: MR_P_BODY] #885705
12/22/10 09:45 PM
12/22/10 09:45 PM
Sure you can....I'll take (1) 12" length (1) 7" & (1) 5" Please....you don't even have to polish it
Rickster
Re: {{{{ THREADED TUBING }}}} [Re: rickstershemi] #885706
12/22/10 09:55 PM
12/22/10 09:55 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
ART in Pinelis has all the dom you want call them and you can get it next day
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: {{{{ THREADED TUBING }}}} [Re: rickstershemi] #885707
12/22/10 09:55 PM
12/22/10 09:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Rickster
I can if you want me too... wish I would have known
earlier today... I was at the steel place picking
up a few pieces
Re: {{{{ THREADED TUBING }}}} [Re: MR_P_BODY] #885708
12/22/10 11:22 PM
12/22/10 11:22 PM
Rickster
up a few pieces
I was just kidding Mike, but might take you up on it if I can't find any tubing locally, but should be able too
But Thanks....!!!!!
Rickster
Re: {{{{ THREADED TUBING }}}} [Re: rickstershemi] #885709
12/22/10 11:28 PM
12/22/10 11:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
These look better and work really well...
Re: {{{{ THREADED TUBING }}}} [Re: Al_Alguire] #885710
12/22/10 11:31 PM
12/22/10 11:31 PM
Nice....are those press-in...???? Who sell's em....???? I still have to find tubing...lol
Rickster
Re: {{{{ THREADED TUBING }}}} [Re: rickstershemi] #885711
12/22/10 11:33 PM
12/22/10 11:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You can get tube adapters from ANY chassis shop. They are welded in, come in left and right hand thread. We usually get ours from here
http://secure.chassisshop.com/
But A.R.T is closer to you.
Re: {{{{ THREADED TUBING }}}} [Re: Al_Alguire] #885712
12/22/10 11:37 PM
12/22/10 11:37 PM
Thanks Al....those are sweet, but think I'll stay with the basic treaded tube
Rickster
Re: {{{{ THREADED TUBING }}}} [Re: rickstershemi] #885713
12/22/10 11:48 PM
12/22/10 11:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is for the tunnel ram linkage right... if so I
use to run 1/4" solid alum drilled and tapped for 10/32....
that still leaves .032 wall on each side... if its
adjusted right you are only overcoming the return spring
so its plenty strong enough
Re: {{{{ THREADED TUBING }}}} [Re: MR_P_BODY] #885714
12/23/10 12:06 AM
12/23/10 12:06 AM
I have a progressive setup and all the pieces are 5/16 fairly thick wall, but too short....need to either find the right tubing or just go with a non-progressive setup....have plenty of time
Rickster
Re: {{{{ THREADED TUBING }}}} [Re: rickstershemi] #885715
12/23/10 01:13 AM
12/23/10 01:13 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Rick
Home Depot or Lowes has 5/16 round aluminum rod, wouldn't that work? just drill and tap
Re: {{{{ THREADED TUBING }}}} [Re: SB412DUSTER] #885716
12/23/10 01:49 AM
12/23/10 01:49 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Rick
Yep Rick
Thats what I done. Just used 5/16 aluminum round stock and drilled and tapped it for 1/4 rod ends. I used right handed threads on each end too. Its not like its a bunch of trouble adjusting it, and once you get it the length, your not going to move it much.
No way was I going to pay $300+ for a cross ram linkage for my engine. I made my own setup for about $30 which included the rod ends.
Re: {{{{ THREADED TUBING }}}} [Re: SB412DUSTER] #885717
12/23/10 09:17 AM
12/23/10 09:17 AM
Rick
Thanks Laverne, I'm planning on ck'ng both today...drilling & tapping is not an issue
Rickster
