Reviving a Brake Master Cylinder #88554
07/14/08 04:05 PM
07/14/08 04:05 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
The car im bringing home tonight has been sitting at least 10 years. I popped the cover off the master and the rear resevoir was empty but the front was still at a decent level.
The brake pedal is totally stiff. The last car I had with a similar condition,I blew the master cylinder up when I pushed the pedal to the floor,with a good deal of force needing to do so. By "blowing up",I mean I pushed and pushed and suddenly there was a loud pop and then the pedal went to the floor and wouldnt pump back up.
Is there any hope in saving this master cylinder? Or should I just bite the bullet and buy a new one?
Re: Reviving a Brake Master Cylinder [Re: SPWC] #88555
07/14/08 04:20 PM
07/14/08 04:20 PM
Andrewh Online content
Andrewh  Online Content
power or manual?
Re: Reviving a Brake Master Cylinder [Re: Andrewh] #88556
07/14/08 04:50 PM
07/14/08 04:50 PM
SPWC Offline OP
SPWC  Offline OP
Manual drum brakes
Re: Reviving a Brake Master Cylinder [Re: SPWC] #88557
07/14/08 04:55 PM
07/14/08 04:55 PM
Sounds like the rubber is stuck to the sides.
If they tear, its done.
You could try soaking it in something like marvel mystery oil or diesel if you have some on hand.
Otherwise you are wasting money and just need to get another one.
Re: Reviving a Brake Master Cylinder [Re: Andrewh] #88558
07/14/08 04:58 PM
07/14/08 04:58 PM
SPWC Offline OP
SPWC  Offline OP
Of course this would mean taking the master off the car...Correct?
Re: Reviving a Brake Master Cylinder [Re: SPWC] #88559
07/14/08 05:01 PM
07/14/08 05:01 PM
places
79powerwagon Offline
places
I simply do not understand the question.
The brakes are shot, they need to be replaced before it hits the pavement under it's own power. You are all jazzed about getting the car but don't want to pony up for the $40.00 (or whatever) for a new master cylinder? You do know that if the MC is shot (and empty) the rest of the system is junk too, right? Almost sounds like a MoparJamie post!
Re: Reviving a Brake Master Cylinder [Re: 79powerwagon] #88560
07/14/08 05:05 PM
07/14/08 05:05 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I would, why take a chance on something that could cause an accident when the replacement part is inexpensive? I've never seen a MC that is frozen due to rust get any better without a complete rebuild.
Re: Reviving a Brake Master Cylinder [Re: Lefty] #88561
07/14/08 05:18 PM
07/14/08 05:18 PM
since the rest of the system is probably shot, then I would just leave it in place.
In the op's defense, if it isn't going to run for a while, why spend money on a part that may go bad or die while you are working on the car.
If it only has to stop when being loaded on a trailer or dropped off the trailer, why not get it to just work good enough and then rip it all out when it is ready to be rebuilt.
Re: Reviving a Brake Master Cylinder [Re: Andrewh] #88562
07/14/08 06:02 PM
07/14/08 06:02 PM
SPWC Offline OP
SPWC  Offline OP
I wasnt implying that I would like to take shortcuts,I simply wanted to know if the master cylinder could be revived. I know its not wise or adviseable,but I just wanted to know if it was possible. Master Cylinders are cheap enough,as I have already priced them,and I will certainly replace the one on the car,prior to making it road worthy.
Re: Reviving a Brake Master Cylinder [Re: SPWC] #88563
07/14/08 06:37 PM
07/14/08 06:37 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
If you were going to change it then why ask?
Re: Reviving a Brake Master Cylinder [Re: stumpy] #88564
07/14/08 07:12 PM
07/14/08 07:12 PM
NW 'Burbs Chicago, IL
A_Roldan Offline
A_Roldan  Offline
Maybe you want to keep it all original? I don't think I'm understanding the question either.
If you want to keep it original, the obvious choice would be re-building it if it is possible at all.
If you don't know whether or not it is a good candidate to "rebuild", then when you are ready to get to it you should have someone that would know for certain take a look at it.
The only way to know would be to take it off and inspect it. At that point, if it is usable or not you can either re-build it, have someone rebuild it for you or simply toss it and get another... it'll have to be removed in any case.
Maybe a little more explanation would help us answer better??
~Angel
Re: Reviving a Brake Master Cylinder [Re: SPWC] #88565
07/15/08 08:56 AM
07/15/08 08:56 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
to even know if you can REVIVE it you will have to remove it and disassemble it , the rear lost its fluid for a reason and the firewall below the master having no paint on it and rust covered , if this is the case , will tell you why .
brake fluid absorbs water , the water sinks to the bottom and rusts the master bore ...
