Re: Reviving a Brake Master Cylinder
[Re: SPWC]
#88555
07/14/08 04:20 PM
07/14/08 04:20 PM
Andrewh
[Re: 79powerwagon]
#88560
07/14/08 05:05 PM
07/14/08 05:05 PM
Posts: 6,516 Santa Cruz, California
Lefty
should I just bite the bullet and buy a new one?
I would, why take a chance on something that could cause an accident when the replacement part is inexpensive? I've never seen a MC that is frozen due to rust get any better without a complete rebuild.
[Re: SPWC]
#88565
07/15/08 08:56 AM
07/15/08 08:56 AM
Posts: 74,969 U.S.S.A.
JohnRR
U.S.S.A.
I wasnt implying that I would like to take shortcuts,I simply wanted to know if the master cylinder could be revived. I know its not wise or adviseable,but I just wanted to know if it was possible. Master Cylinders are cheap enough,as I have already priced them,and I will certainly replace the one on the car,prior to making it road worthy.
to even know if you can REVIVE it you will have to remove it and disassemble it , the rear lost its fluid for a reason and the firewall below the master having no paint on it and rust covered , if this is the case , will tell you why .
brake fluid absorbs water , the water sinks to the bottom and rusts the master bore ...
